anyone have an axle spacer? I need one for my Talon hub. (the one they sent me is way too short. according to my caliper the out side diameter is 30mm, and Im pretty sure the axle is 25mm. anyone have one? or at least point me in the right direction.
Seems to me Talon is the one you should be contacting. If all else fails, a local machine shop could fab one up for you. You're probably not going to find one off the shelf.
with the right dems. width, OD, ID, i could make you one..i charge 45.00 an hour for shop time... with a one hour, min..
I had one made locally. I was hoping someone here might know of a Talon dealer in the states that had something.
so, did it cost ya 20.00???i dont know a real machinist that would even trun on a lathe for less then a 75.00 hour min... board average is 95.00 and hour.
