125-200cc I need help
Discussion in '2 Stroke' started by Roberto, Jan 4, 2014.
  1. Roberto Husqvarna
    Lagoa Formosa (MG) Brazil
    Husqvarna WR125
    Honda CRF250X
    Hello friends
    I need some photos, PDF files, videos or tutorials on how to reset the axis of the pedal rates Husqvarna WR 125.
    Can someone help me.
  2. Motosportz CH Sponsor
    No idea what that is ???
  3. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    first step adjust the cudsmotyline controls then set the masgadentfor :excuseme:
    LAHuskyrider likes this.
  4. flyingbob Administrator
    USA
    01&02WR360_02WR250_02CR250_12WB165
    01 VOR400_07 TM450_22 GG250_07 Tuono
    I'd guess Roberto wants to install his power valves...:excuseme: or install the footpeg springs...:thinking: time will tell
  5. Roberto Husqvarna
    Husqvarna WR125
    Honda CRF250X
    picture,video how to replace
    how to replace the selector
  6. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    ok looked at the pixs we know what he broke wth dozy want to know wont that shaft go in from the clutch side who speaks brazilian portuguese?
  7. Roberto Husqvarna
    Husqvarna WR125
    Honda CRF250X
  8. Roberto Husqvarna
    Husqvarna WR125
    Honda CRF250X
    would like to know how to replace, remove
  9. 2premo Husqvarna
    Northern NV
    axis of pedal and selector = shifter ;)
    guessing he wants to replace the shifter as well as the shift shaft :confused:
    not to mention pics of a shifter and shaft are kind of a giveaway :thumbsup:
    R-J van Hulst and Motosportz like this.
  10. Roberto Husqvarna
    Husqvarna WR125
    Honda CRF250X
    yes
    I need a tutorial or pdf file
  11. AUSKY Husqvarna
    Cairns, FNQ,Australia
    08 TE510 96 WR125 00 WR360 13 WR165
    1999 XR250 83 YZ 490
    Hi Roberto
    It is a simple process, you will need a new side cover gasket
    1. Remove exhaust and select neutral
    2. Drain the oil and the coolant from the engine and remove hose from water pump outlet
    3. Remove gear lever/pedal from selector shaft(LHS)
    4. Remove RHS side cover, clutch cover can remain on side cover.
    # Note how the selector shaft hooks over the shift drum pins, with the double hook
    5. Remove gear selector shaft assembly from engine by simply pulling on the end of the shaft.
    # It should come out easily, if not you will need to push the gear lever side (LHS) of the shaft.
    They normally come out quite easily.
    6. Install new selector shaft through engine
    # make sure to put the double hook back over the shift drum pins the way it came out. This will allow the selector shaft to engage the shift drum
    7. Check the length of the splined end of the selector shaft on the LHS side to allow the gear lever/pedal to seat correctly on the splined end (LHS) of the shaft.
    8. Install gear lever/pedal and check gear selection
    8. Clean off old gasket and replace with new one
    9. Reassemble the side cover, exhaust and water pump outlet hose
    10. Fill engine with oil and coolant and check for leaks
    Then your good to go
  12. Roberto Husqvarna
    Husqvarna WR125
    Honda CRF250X
    Thanks already helped me a lot friend
    I need more pictures of how to do
    Motosportz likes this.
  13. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    yea what he said see we can fix'em fix'em all fix'em so they stay fixed LOL
  14. chris anders Husqvarna
    2002 CR250 , 2002 CR125
    2003 Suzuki RM250
    R-J van Hulst likes this.
  15. sabortooth No Class
    Izard Co. Arkansas
    11uptite167
  16. R-J van Hulst Husqvarna
    Cambodia
    Honda CB 400 Vtec 3
    To all big thump up :thumbsup::thumbsup::thumbsup:
    I've seen similar request for info on other forums and the guy was totally brushed off as a lunatic.
    happy to see the responses from the crowd I feel also part of :thumbsup:
    Robert-Jan
  17. sabortooth No Class
    Izard Co. Arkansas
    11uptite167
    Dammit.
    I knew that was going to harm my image.
  18. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    sabortooth you have no image look at your profile pic an up load one :lol:
    roberto, im about to strip my 2002 360 bottom end to do main bearings i will be taking the shifter and drum out if you like i can take pics and upload and explain what im doing, not sure of your year but it may be a help.
    sabortooth, R-J van Hulst and Roberto like this.
  19. Roberto Husqvarna
    Husqvarna WR125
    Honda CRF250X
    You do that for me, my friend
    Will be of great help, I will wait for the photos
    thank you very much
  20. wallybean Mini-Sponsor
    Montana
    Unfortunately the 360 shifter doesn't go through the tranny and is quite a bit different. I will be doing this in a couple of weeks and can do a pictorial for you but that is a long way off. It really is fairly straight forward on the 125 so you should be able to handle the procedure.
