TE/TC I need Jet info
Discussion in '2st' started by markh, Jan 24, 2016.
  1. markh Husqvarna
    2014 TE 250
    Hey there guys.. I just moved to another state and in the process I seem to have misplaced the manual to my 2014 TE250 ..
    I'm at sea level now, anybody know what size jets I need ?
  2. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
  3. Trikk Husqvarna
    TE300
    RMZ450
    Reveille,
    Did you read the manual you sent a link to? Every reference I found, refers you to your local dealer regarding jetting. My 16 TE300 didn't come with a manual is the reason I checked this out.
    New
  4. Trikk Husqvarna
    TE300
    RMZ450
    Realized that post might sound a little dickish. By "did you read" I mean may be I missed the specs somehwere in the Pdf.
  5. markh Husqvarna
    2014 TE 250
    @ Trikk
    go down to page 119 of the PDF or to page 117 of the manual
    its got the specs for the elevation and temperature range for the TE 300.
    @ Reveille
    thanks for the quick reply bud, it was just what I needed!
    Trikk and reveille like this.
  6. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
    Kam1 likes this.
  7. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
    You're welcome. I prefer the PDF manuals when working on my bikes and as you found out, if read properly, there is very comprehensive information to be gleaned. I just picked up a new 2015 300 myself but being I'm jetting illiterate, I installed a Lectron. Enjoy the new bike.:cheers:
  8. Captain Kirk Husqvarna
    '15 FE350, '15 TE300
    2011 FE570S, '08 KTM 300 XC-W E
    Don't mean to derail the op's thread, but since you mentioned it..........what did you do if anything about your air filter boot? I just fitted the 36mm Lectron to my '15 TE300 and upon looking down into the throat from the filter vantage point, I can see significant boot buckling that I suspect will be a restriction in the upper rpm and I see that the filter is now a fuss to get a perfect fit which is a risk point for a future failure IMHO.
  9. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
    Lectron instructions were to cut the boot back to the second ring at the carb side. I also carefully trimmed the second ring tab flush with the outside of boot to allow the clamp to sit flat and not slide up when tightened. The rings tab is useless since it sits up against the lectron so shaving it down allowed the clamp to be closer to the lectron where it needs to be. No buckling now. Not sure if you get my response or not. If you have more questions, pm me. BTT
  10. Captain Kirk Husqvarna
    I've done some modifying and I now know what I want to do. I've found that the Gorilla Gel Glue equivalent to Super Glue is extremely compatible with the boot composition so I am ordering a new boot and I will remove 14mm of the boot neck a bit away from the rings. I did what you suggested and not that your suggestion is wrong (I actually did it before I came back to the forum) but I don't trust the clamp not to slide. I played with the clamp after thinking I had it tight and secure and I was able to move it even with it clamped really tight. Just can't trust that so I'll remove the ring and reattach it. Thanks for the help though!
