So, I was fueling up my TR650 today using those wonderful (sarcasm) California gas pump fillers. These are the ones that require you to push down to provide a seal against the gas tank so vapor doesn't escape into the air. A real pain. Anyway, I pressed down like I always do and the I hear a "plop" and no resistance. It appears that the red fuel tank tube popped off and went into the gas tank. Has anyone experienced this? If so, how'd you get it back out? Also, is that tube really needed? Thanks in advance. Aside from this, my TR650 has been a wonderful bike.
I removed the red funnel thingamajig for easier filling. You don't really need it. You just need to pay a bit more attention that you don't overfill. Leave about 2cm to the filler hole, anything over that will just come out the overflow tube. Getting your funnel out could need a bit of fishing, or if that doesn't work, take out the fuel pump and see if you can get at it from the bottom.
Thanks for the feedback. I figured it was an "optional" piece of equipment. I'll be careful not to overfill, too!
I always use a finger to make the pump run. There is a switch in the pump nozzle to ensure there's a "seal". I just grab it at the tip of the snorkel with the index finger of the hand not squeezing the handle and pull it up until the gas flows. Takes a little practice, but once you get used to it it's easy and ensures a proper fill up each time.
