125-200cc I wanna go faster
Discussion in '2 Stroke' started by bigmick, Oct 20, 2013.
  1. bigmick Husqvarna
    200 wr 250
    I'm looking for more power from my wr250 & was wondering if the 360 top end can be fitted also
    every time I see the specs it says my bike has a six speed box mine definately only has five & I can account for the bikes entire life its never had either the engine or gearbox opened so wheres my other gear .
  2. jd117 Husqvarna
    lake geneva
    What year is your bike ? Edit : In your avatar do you mean a 2000 model ? If so I think they were 5 speeds.
  3. uranys Husqvarna
    Pittsburgh, Pa
    96 xr600r
    My '09 250 is way faster than my '00 360. The 360 has more grunt, about the same mid but nothing up top where the 250 takes off.
    Never rode a 300 but hear good things about them and the top end would probably fit your bike
  4. bigmick Husqvarna
    200 wr 250
    Yeh its a 2000wr still has good compression & embarases a lot af new bikes but it is getting on & doesn't have the same poke it used too. With the gearbox the spec sheets definitely say six speed for that year & it feels like it needs another gear plus very rarely it will jam in gear & has to be turned off & rocked to get it out .I am about to do a complete rebuild so any advice to get more bottom end & midrange would be great
  5. Chef Husqvarna
    Ontario, Canada
    08 Cr165, 09 Wr165
    01 Husaberg FE650, 07 BMW 650 Dakar
    I have a 2000 wr motor and it is a wide ratio five speed.Eric Gore(sp) ports them and he has a kit to go 265 or so. I talked to him a couple years back when I was due for a rebuild but in the end, did it locally.
  6. ohmygewd Husqvarna
    Melbourne, Australia
    Aprilia RSV1000
    360 top end won't fit in a WR250 motor...different motor altogether.
    You can get a Eric Gorr big bore kit for a WR250 which will bring it up to a 295cc which can be expensive if your from Australia so do you have a budget for this bike for the rebuild?
    If your from Victoria or NSW, give Dave McCarthy from two stroke performance a call and get a quote on a big bore kit and he can do the porting, squish and jetting.
    2k WR250 had a better bottom and mid then most 250's in that era so a couple of easy mods like gearing and change from OE pipe to a FMF gnarly does wonders.
  7. outdoorsman166 Husqvarna
    2008 WR250/1987 430xc
    The 250 can be changed to a 300. A local husky dealer told me if I do the switch id have to change pipes or the bottom end would be too hard to control. This confused me because I thought the 250/300 had the same pipe factory. But the mid and top I was told would improve a good amount
