Hi all, does anyone have any info or details on pinouts for this cable. Is it just an RS232 connection? Ta
It's not RS232 at the bike. There is a communication interface circuit between the computer and bike. The factory Mikuni cable has the circuitry inside an epoxy block in the middle of the cable. The SEMCO interface cable has the circuitry inside the connector at the PC end. Also the cable that connects to bike is replaceable in case it's damaged. You can get the interface cable & iBeat here... http://semcodesigns.com/Products.php
Wish husky would send a cd and cable with the bike. The cost of the software i can understand but the cable and converter is abit rich. Hrmph
Worth every penny if your a do it yourselfer. Semco design cable is top notch, and service it 2nd to none.
Maybe worth a look. I recently flooded my bike (09 te450) Now it won't start. Checked all connectors and cleaned. Spark plug/ compression ok. Pulled off throttle body.. seems ok. Turns over and pops and crackles but won't start. I fear the worst, I assume the software would indicated the problem.
My '08 TE 450 died once like that, it spun over fast and sounded like I lost a valve. It turned out to be the EFI popped off of the air boot.
