Identifying P/U kit, and other ?'s
Discussion in '610/630' started by littlehandegan, Jun 19, 2013.
  1. littlehandegan Husqvarna
    Picking up a 2011 Husky TE630 with 2,000 miles from a dealer. He says it has P/U kit installed but I want to make sure.
    How do I check?
    Also, any MUST do modifications to increase the bikes fun and safety?
  2. riz Husqvarna
    Jakarta, Indonesia
    2011 SMR 630, 2012 WR 250
    Vespa S150, Honda XL200 Scrambler
    Simple way: If there's a brass plug in the header, then it's confirmed. But if the 02 sensor is plugged into the header, chances are no PU kit.
    Must Mods: I'd go ASAP with axle sliders and handguards just to be on the safe side. Then final gearing to suit the traffic you live in.
    Enjoy the bike!
    EDIT: I overlooked that it's a TE...you might not need axle sliders offroad but bashguards/skidplates are a must
  3. 1lunger Husqvarna
    Bloomfield CT
    Must do MODS are as follows:
    JD tuner
    LV x 3 slip on pipe or full system and 1 can
    Light weight battery ( not a must, but takes some weight of )
    Ck and make sure the recall on the rear sprocket was completed
    Good chain
    Seat concepts seat
    Bash plate and hand guards
    Most likely some better tires (depends on the type of riding you're doing)
    Welcome and enjoy!
  4. littlehandegan Husqvarna
    Thanks
    Funny enough I have the new sprocket in a box my dealer sent me when I owned an SM a while ago.
    How can I tell if it is the old style?
    Also, whats the easiest and best plug and play tuner?
  5. 1lunger Husqvarna
    Bloomfield CT
    JD tuner
  6. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    2013 Kawasaki ZX-14R
    It isn't the sprocket that was recalled, it was the bolts. Specifically, the nuts.
