waserman
I thought all the adjustments had to be made via I-beat through the processor.I was under the impression that on a fuel injected bike that any adjustment that is made to the throttle body settings,for example adjusting an external screw on the throttle body,would change the settings for the bike throughout the entire range of motion,or throw off the TPs setting.The reason I ask is that my idle could stand to go up a little and it might help hot starting after a stall.I also have about 440 miles on the bike and haven't touched any of those adjustments and have the power up kit on an 09 TE510.I have had to change relays and the temperature sensor,because of no starting when the bike was hot as in up to operating temperature.I recently checked/adjusted my valves and put them in the middle of the tolerance specs,they were out of tolerance on the loose side,odd I thought I expected tight. Thanks John
