Idle speed
Discussion in 'TR650' started by Nordland, Jul 2, 2014.
  1. Nordland Husqvarna
    North of Germany
    TR 650 Terra
    After the update of the mapping of my Terra the idle speed is a little bit unstable. Sometimes jumps about 50/100 r/min up and down.
    I have already reseted the TPS and idle speed sensor, made it a little bit better but it´s not gone completely.
    It would be interesting for me to know if anyone else has this symptom on his bike or run all other bikes stable? Please let me know, thanks.
    By the way... I just want to know what the idle speed of other bikes is and don´t need any advice how to probably fix it. This should belong to consisting warranty. Thank you ;)
  2. drzcharlie Husqvarna
    1500 rpm is OEM idle.
  3. kiwiape Husqvarna
    650 Terra
    Aprilia DD750
    1500-1600rpm OEM always been a bit lumpy, but I'm ok with that, it sounds cool:) , otherwise it would sound like a lawn mower...
    Nordland likes this.
  4. Nordland Husqvarna
    North of Germany
    TR 650 Terra
    For a non-native english speaker: "lumpy" means that idle speed is not stable? Jumping from 1.500 to 1.600?
  5. kiwiape Husqvarna
    650 Terra
    Aprilia DD750
    correct, not constant, varies between 1500 -1600rpm.
    IMO this is not a topic to spend much time in the scheme of things, just as long as it keeps running, that's the important bit.....there will always be some variation and we are only talking 100 odd rpm in a big single that will happily rev to 8K!,....there's always a compromise somewhere, you cant have it all.
    Nordland and Quirky like this.
  6. AUS_TR650 Husqvarna
    Australia
    2008 KLX250S
    +1.... and free up the exhaust so it does not sound like a farm bike when riding!
  7. Nordland Husqvarna
    North of Germany
    TR 650 Terra
    Will have my Terra MOSSed tomorrow, then I will know more.
    :lol:
    FER QUILES likes this.
  8. drzcharlie Husqvarna
    Hey, if you can ask the technician what version of the MOSS software your bike is receiving, we would all be grateful to know.
    Nordland and Lekolite like this.
  9. kiwiape Husqvarna
    650 Terra
    Aprilia DD750
    Heres some shots of what you are looking for. I am not sure the version of MOSS is that important now, it just has more features for the technician. The MOSS Tool will go to the server and update your bike to the latest (and theres no going back). Its the "prog.ECU" thats import, this is the ECU software revision version and the latest is #8543235. Good luck mine is still not right......I believe we have an ECU problem, time will tell and I will.
  10. Nordland Husqvarna
    North of Germany
    TR 650 Terra
    Sorry, but only the TPS and the idle adjuster will be relearned with the MOSS tool. Not a completely new mapping. This was made in april, but I don´t know which version.
    @kiwiape: There is an way back to the old mapping
  11. kiwiape Husqvarna
    650 Terra
    Aprilia DD750
    @kiwiape: There is an way back to the old mapping[/quote]
    From my experience and from advice given to me by others who use the MOSS Tool, you cannot go back to old ECU update. Sorry I just notice my picture is wrong with the ECU versions..I will try to fix this:doh: .
  12. Nordland Husqvarna
    North of Germany
    TR 650 Terra
    The workshop of my confidence told me that there is a way back to the original mapping and that they already did it a few times.
  13. kiwiape Husqvarna
    650 Terra
    Aprilia DD750
    Please take a photo of the MOSS Tool screen showing where you can back-up ECU updates.
    Pic attached of ECU directory tree, DME = ECU, ABS= ABS, KOMBI = DASH
  14. Nordland Husqvarna
    North of Germany
    TR 650 Terra
    Unfortunatly it didn´t work as planned. So nothing new.
    Sorry kiwiape, the dealer who told me is about 400 km away...
  15. FER QUILES Husqvarna
    SPAIN
    TR650
    KLE500, HONDA NX650
    I did the procedure to disconected battery for 1 hour and follow the right way to conected back and twist , left the fun running.
    at the moment no iddle stall at all. I wil go advising news .
    it seems to go much better, but I have to wait a couple of days to analysis all situations.
  16. Nordland Husqvarna
    North of Germany
    TR 650 Terra
    Today I was in another workshop and they made it. The TPS was relearned and the idle adjuster calibrated with the MOSS tool.
    Now it´s great, No more of this unstable idle speed, just little jumping as it´s normal. No stalling, the bike runs perfect.
    I don´t need any booster, wuka or eruption, only an exact calibration of the injection system.
    @kiwiape: The surface of the MOSS tool here looks a little bit different than the one on your pictures. Maybe that is the solution?
  17. kiwiape Husqvarna
    650 Terra
    Aprilia DD750
    it sounds like you have the older version MOSS (V14) in which I saw how to recalibrate TPS. How far have you riden it?, it can take a few k's before it stumbles and around town is the best place.
  18. AUS_TR650 Husqvarna
    Australia
    2008 KLX250S
    Hey Nordland, I had mine reset last week as it had the same symptoms as your bike with the same outcome. Easy to tell it was relearning as the fuel cut-in while coasting was a little harsh but it sorts itself out after a good ride.
    Like you, never had a Wuka or booster as I find it works okay without one.
  19. FER QUILES Husqvarna
    SPAIN
    TR650
    KLE500, HONDA NX650
    at the moment go on unstable idle speed, next revision i will try to calibrate with MOSS, to see.
  20. Nordland Husqvarna
    North of Germany
    TR 650 Terra
    This morning, outside temperature about 12° Celsius (15,5° Celsius at the dash) - 54° F/60° F - the idle was perfect :thumbsup:
