250-500cc Ignition 8000 75345 Ignition Device
Discussion in '2 Stroke' started by 2premo, Feb 24, 2017.
  1. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    my 99 360 has an electronic control for the ignition on page 61 of the parts catalog called "Electronic Device", obviously it is an ignition control
    does anyone know how it functions and how to test it
    I am having an ignition problem and the coil is fine the mag is new and suddenly the bike seems to just not run right at times, end of last ride thought I might have been out of fuel but had plenty, 10 minutes into the next ride there it was again, even had a weird vibration, buzzed my feet, pulled the clutch, checked everything internal including smoothness of the main bearings, no obvious rod issues
    checked the Lectron carb and fuel passages are clean, bowl is full and it seems to just not run right
    wondering if this can be a problem, checked all the connections including ground and this is the one thing I know nothing of and was wondering if anyone ever had to replace one??????
