Ignition Switch Adding....
Discussion in '4 Stroke' started by matt mckibben, Aug 29, 2018.
  1. matt mckibben Husqvarna
    san anselmo, CA
    te250 2007 love it!
    KTM?Husky switch uses a 6 pin block, turns out its a standard Molex .093" series plug
    part number 1261PRT... and most of the plugs on our (2007 for me) Huskies are from Molex.
    now can anybody point me to a wiring diagram that has a stock ignition key switch?
    (I'm adding a ket switch to my 2007 te250)
    thx, Matt
  2. Trenchcoat85 Husqvarna
    Northern NorCal
    '14 TE 310R
    to tell you the truth, I don't know the differences in the '07 models (blue/yellow vs. red/white; carb vs fuel injection probably) but this repair manual is for the E series models:
    http://docs.wavenetworks.us/manuals//2007 E-Series 250-450-510 Repair.pdf
    and this one is for the plain-jane earlier '07s:
    http://docs.wavenetworks.us/manuals//2007 ALL 250-450-510 Repair.pdf
    you can find other manuals here:
    https://husqvarnaoutlet.com/repair_manuals
    (look around, they have parts manuals too)
    this screen grab is for the e-series... the ign switch is #26
  3. Highflyer Husqvarna
    Norway
    TE 450
    Husaberg FC550,FE650, Kawasaki KX250
    But this diagram does'nt show how to connect to the colours from the stock key switch. It's a whole different combo of colours from the switch and into the plug. I struggle to find this out because I have use another plug, and dont know what colours to put together.....
  4. Trenchcoat85 Husqvarna
    Northern NorCal
    '14 TE 310R
    well, I'm not gonna dig too deep...
    but just reading my screenshot of the harness connector above:
    connector pins 1-2 (blue, white/blk stripe) are shorted when the key is OFF and open when ON
    pins 3-4 (red, green/red stripe) are shorted when ON and open when OFF
    pins 5-6 (yellow, red) are shorted when ON and open when OFF
    [note: electrically, 3-4-5-6 are shorted together when ON because they're using the same red wire]
    the green/red stripe wire may be gray/red stripe (Italian translation issue).
    none of this info is guaranteed.
  5. Highflyer Husqvarna
    Norway
    TE 450
    Hi.
    I solved the mistery.
    I had to use a ohm-meter to find out.
    The wiring on the key switch (8000A8903), have these colours:
    -Green
    -Orange
    -Yellow
    -Black/green
    -Red/white
    -Blue.
    Sooo.....
    Then the key is in OFF position, it connects Red/white>>>>Blue!
    When in ON position, it disconnects Red/white and blue. And connects Yellow>>>>black/green. And Green>>>>Orange.
    So, now it is much easier to understand how to connect these wires to the diagram. :-)
  6. Trenchcoat85 Husqvarna
    Northern NorCal
    '14 TE 310R
    congratulations- wasn't that hard was it?
    so going by your colors on the key ignition side of the connector- the blue wire is pin 1, red/white is 2 (or IOW: blue, white/blk wire pair on the bike side of the connector).
    give future readers the rest of the pin numbers (actually, if you connect a pair to the green, orange pins and the other pair to the yellow, blk/grn pins- it should be fine).
    there are many times that suppliers use different colored wires on "their" side of a connector- the speedo comes to mind here; so you have to do this kind of investigation using a meter.
    good luck.
  7. Highflyer Husqvarna
    Norway
    TE 450
    No. It was'nt that hard.....when a friend showed me HOW to use a meter, and what to look for. :rolleyes:
    I'm waiting for "the right" connectors to arrive, and will update you as soon as I have done the job and have quality checked my work. :-)
    Trenchcoat85 likes this.
  8. Trenchcoat85 Husqvarna
    Northern NorCal
    '14 TE 310R
    0.093" molex pins?? CRS
    shorted means "connected"
    open means "disconnected"
  9. Highflyer Husqvarna
    Norway
    TE 450
    Yup. I bought some Molex 0.93" 6 pinns connectors, and they were the right ones.
    So...
    Through this connectors I wired it this way:
    (Key switch>>>Harness on bike.)
    Green>to>Green/red
    Orange>to>Red(thin).
    Yellow>to>Yellow
    Black/green>to>Red(thick)
    Blue>to>Blue.
    Red/white>to>(2pcs))black/white
    So, now when I switch the key the instruments lights up and the digital numbers shows. And when I push the kill switch to OFF, I can push START button, and it starts up. Then the rpm and "lights on-indicator" and "neutral-indicator", both green lights, lights. I can kill the engine both with the key, by switching to OFF, or push kill switch. Niiice!
  10. Oaca Stefanita Husqvarna
    Romania
    TE 510 2008
    Yamaha FZ6 Fazer
    Hi, can you post some pictures of your mod? My key fell off while I was riding the bike and I want to use a switch instead of it.
