250-500cc IMS Tank install 2011 WR300
Discussion in '2 Stroke' started by icebergstu, May 14, 2013.
  1. icebergstu Husqvarna
    South Australia
    WR300/TE610e
    WR360 CT110 XR100
    Seems as though the only thing holding this tank on is the 8mm long bolt that the Seat couples to at the front?
    Is this correct?
    Once installing this bolt, when putting the seat back on - the seat coupling now will not reach down far enough to mesh with the bolt??? Do you just run the seat front loose or is there a mod?
    Has anyone put another petcock in to the throttle side of the tank to run as a reserve or do you just tip it over when it is low?
    Stu
  2. huskybear Husqvarna
    B.C. Canada
    I have installed a dual pet-cock on my wr150. Search my thread"making the most of your stock wr fuel tank":cheers:
  3. husky3002t Husqvarna
    wr300
    yes one 8mm bolt holds it,my seat fits fine with my ims tank
  4. icebergstu Husqvarna
    South Australia
    WR300/TE610e
    WR360 CT110 XR100
    I put a couple of washers in and it sits fine now.
    Thanks
    Stu
