Info For Starter Motor + Stater Drive For TE 250 2010
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by JLou, Mar 10, 2013.
  1. JLou Husqvarna
    250 TE 2010 ( New Motor )
    TWO KTM GS 125 1984 + 1985
    Hi all,
    Today, my Starter Motor + Starter Drive Fixing have broken and i lost my motor oil by the entry of Starter Drive because all are go off their place.
    I m from France, can anyone tell me where i coul'd to buy it or anyone have one even use?
    Thank You
    PS: It's an EFI Bike
  2. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
  3. JLou Husqvarna
    Ok, thanks, i don't understand all what it say, but, mine never had trouble to start. My impression is that 2 of 3 screw locations are broken suddenly
  4. glangston Husqvarna
    2012 BETA 350 RS
  5. JLou Husqvarna
    The Problem is there no more importer in france since december and it's difficult to have parts which are not in stock in the dealers
  6. Phoenix Husqvarna
    Oklahoma City, OK
    2009 TXC 450
    2 Ducs, 14 GG 200, 13 Husa 300
    Can you post some photos? I'm imagining the starter broken away from the case, but I hope I am imagining wrong.
  7. glangston Husqvarna
    2012 BETA 350 RS
  8. aethelred Husqvarna
    UK
    What has happened is the bike has back fired while you had your finger on the starter button and pushed the worm gear out of the crank cases!
    The worm gear looks like this:
    I this correct?
    There is a small oil feed through the gasket to the starter motor right angled bevel gears which is hard to spot...
  9. JLou Husqvarna
    Yes it's correct, because after the fixing are broken, I had back fired on the kick.... that i have never had before.... While waiting for the warranty; i have made a parts on my work, with my lasercut ( 2.5Kw 3015S LVD for the expert ), an inox 40/10 + alu 30/10 part with O-ring or homemade gasket to close the hole for starter... and finally, it's not a problem to kick as she is very easy to start with it...
    And if someone are interesting for my personal part to ride without starter, you can contact me..
    PS: Yes, there is a small oil feed trough the gasket... but it's not a problem now....
