input on mossbarger reed set up
Discussion in 'Vintage/Left Kickers' started by 81huskycr430, Apr 13, 2010.
  1. 81huskycr430 Husqvarna
    washington state
    hey boys, anyone used a mossbarger reed set up would like pros and cons on how much better is it than stock 1981 cr 430 set up.
  2. Leftcoast leftkicker Husqvarna
    encinitas ca
    It's good if you're a faster guy (upper end breathes better) but when combined with a flat slide carb it rips. Just remember that it's about 3/4" longer than stock so you need to trim the air boot.
  3. 81huskycr430 Husqvarna
    washington state
    leftcoast, so do you go up to 40mm carb from 38mm, thanks.
  4. Leftcoast leftkicker Husqvarna
    encinitas ca
    Nope, stay with 38- easier to get jest & better low end response
  5. Gasitt Husqvarna
    Moss. Reeds
    Gday 81,
    As lefty has said mate better top end you need to get the barrel ported to really take advantage of the reeds and the 38mm is the go more air speed the pic bellow is a set on my 420 Auto and they are longer so as lefty said the boot needs a trim go bigger on your main and richer on the needle ride it for a while checking the spark plug color then gradually lean it off until it feels best.
    They look awsome/trick :D
    Gasitt!:thumbsup:
