250-500cc Instructions for top end rebuild WR-300
Discussion in '2 Stroke' started by Oldmotocrosser, Dec 19, 2015.
  1. Oldmotocrosser Husqvarna
    Calgary
    2010 WR300
    None.
    I have rebuilt a few dirt bikes in my day, but I am told that the newer 2010 WR 300 needs a coating on the cylinder walls once it has been honed or bored out. This is a first time I have ever heard of a nickel coating, but as I am a llttle rusty about this, perhaps this is true...
    Does anyone know about this?
    There should be a web site for the rebuild, I used to have my Suzuki manual, and it gave a complete top end instructions for my RM-125. It was thorough. Does anyone know of the same online manual for the Husky WR-300?
  2. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    juicypips likes this.
  3. Eaglefreek Husqvarna
    Fayetteville,TN
    11 WR300
    Big Timmy and NCSteve like this.
  4. SpeedBallRacer Husqvarna
    Milwaukee, WI
    2007 WR 250
    Buell XB12X
  5. Mobil1 Husqvarna
    Wr 250 2003
    Sure you can hone a nicasil cylinder, normally you always do when putting new rings.
    But you need diamant hone with fine profile.
    And like others, while you hone the diameter of the bore increases.
    With nicasil only being a coating, you cant take off much... Also match your piston to bore size...
  6. Crocus Paper Husqvarna
    UK
    WR250
    Scorpa 300 Aprilia Dorsoduro 750
    I've been researching coatings myself recently. After a fall from my trials bike it stuck on full throttle resulting in melt down, despite pulling HT lead off spark plug!! It kept running.
    For me the 'rule of thumb' is NOT to hone. You can, if the coating is thick enough. Typically thicknesses will be about 0.002". Some coatings can be applied up to 0.006" thick which would allow honing (with the correct material honing tool) but the thicker the coating the higher the likelyhood of chipping. The best idea, as stated above, is to give the piston you're installing to the plater, he can apply a coating to the bore to match that piston.
  7. Mobil1 Husqvarna
    Wr 250 2003
    Rule of thumb is when putting new rings you need to clean up the bore.
    This means honing the bore.
    Pistons are in diffrent sizes, dirtbikes mostly have a,b,c pistons.
    Most likeley his bore will be fine and he can use the b or c piston, if he has the possibilty he can let his dealer clean up the bore and supply the correct piston.
    Replating here cost arround 250€... Costly rebuild then and not neccassry.
    Also, if you or your dealer doesn't have the tools to clean up the bore just place the new piston. It won't go bad...
    With the vertex pistons the sizes are printend on the piston crown. If you remove the cilinder head you will see this.
  8. Cosmokenney Husqvarna
    North Auburn, CA
    '17 TX300
    Yamaha FZ-09
    Is it possible to find the piston size on a stock piston using a bore scope?
  9. Mobil1 Husqvarna
    Wr 250 2003
    You can try but i have my doubts, carbon build up...
    Do not know if standard piston has it marked on top?
    Vertex pistons do...
    Try the bore scope, if ot doesn't work pull the head. 30min work max...
    Cosmokenney likes this.
  10. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    All the pistons ive used or seen have markings on the top or casting marks either side of the gudgeon pin.
  11. rancher1 Husqvarna
    WA
    Most likely not since the difference between pistons is .01mm or .00039 thousands, yes that is 39 ten thousandths, not much at all.
  12. Joedints Husqvarna
    Medford, New Jersey
    11 WR300 13 WR125 81 WR430 82 CR250
    Kawasaki ZR7-S
    There are 3 bore sizes of the OE cylinder for the 300. They are marked on the cylinder with an "A, B or C". It has to do with the finished bore size and the correct piston. Find the marking on your cylinder, normally stamped on the reed area, and order the matching piston, if you are sending out the cylinder to be replated, you have to send a new piston with the cylinder or buy one from them.
    I like PowerSeal for this work (Outside of Philadelphia).... http://www.powersealusa.com/
    if you need a pic, look at this......http://www.cafehusky.com/attachments/image-jpg.53673/
