250-500cc interior engine bolt torque
Discussion in '2 Stroke' started by LBBKserg, Jan 24, 2018.
  1. LBBKserg Husqvarna
    Washington
    2010 300wr
    05crf450,07yzfr6,08xcf-w250,01exc525
    image1.jpeg so I'm in the middle of getting ready to reassemble my engine case and this is the first time I have ever done something like this(rebuilt the entire bottom end) and Im trying to figure out how am I suppose to know what these bolts are called and their torque setting.
    It says y m c 10.9 is the 10.9 the torque?
    thanks!
  2. taps Husqvarna
    TX
    '94 WXC360
    '15 RMZ450, '08 RM250, & '74 MX360
    10.9 will be the bolt grade
    You can check this site for what the grades mean.
    https://www.boltdepot.com/fastener-information/materials-and-grades/bolt-grade-chart.aspx
    I always find it difficult to sort through the list of torque specs in the manual, but if you can't find exactly what you are looking for, they also have a general torque specs listed for standard sizes.
    And someone will certainly chime in saying, "Tight is tight." I also prefer a torque spec when it is possible. :)
    That's about all the help I am at the moment. At least it takes care of one of your questions!
    LBBKserg likes this.
  3. LBBKserg Husqvarna
    Washington
    2010 300wr
    alright thanks can't seem to find any info in the manual so difficult to look at with 5 different languages in the same paragraph haha most likely blue loc tight and tighten it
  4. pvduke Husqvarna
    ... on the gas...
    tripple-hondo hoosk...
    yup. that screw head pocket wont take a lot of torque in some cases that type of socket (hex/torx/phillps et, al.) will blow out before the shank can stretch appreciably. if there's no spec on the call out sheet i usually just clean the hole and screw shank well- brak-kleen/cotton swab/air gun to get it spotless then add a small drop of blue loctite and snug her down. to remove it if ever nec heat the head with a pencil torch to soften the locking agent before trying to remove.
  5. LBBKserg Husqvarna
    Washington
    2010 300wr
    yep i learned on one of the bolts, bearly torqued it and stripped. had to use the trusty wedge tool and hammer almost couldn't get it
    thanks guys!
    pvduke likes this.
