Intresting ride!
Discussion in 'Vintage/Left Kickers' started by toolie, Aug 9, 2016.
  1. toolie Husqvarna
    Ontario, Canada
    1986 400 XC, 2018 TE300
    1986 Can-am 250 ASE-sold, 1985 RZ500
    So I was out for my second ride, on my new to me husky, working on the lean jetting issues and trying to get the starting procedures figured out. Thanks to this forum for the starting techniques they are definitely helpful! After stopping for a quick break and checking the plug I started the bike and it sounded a little off. I put it in gear to drive off and to my surprise ......IT WAS GOING IN REVERSE!:eek: WOW that was a shock. I hit the kill switch and started it again with no issue. I guess there was enough of a kick back the engine actually fired up? Any one else have this happen before. My 2005 Ski-doo MXZ has an electronic reverse which is the engine running backwards.
  2. Joe Chod Husqvarna
    upstate NY
    if on a big bore (400) and timing should be around 3mm BTDC and it ran in reverse, I would check where it is firing as that generally occurs when to close to TDC not like 3 mm before
  3. toolie Husqvarna
    Ontario, Canada
    Thanks for the info. I'll have to check the timing. . Is 3 mm btdc the correct specs for this bike?
  4. DPete Husqvarna
    Farmington, Ca
    1972 WR250 76' 360 WR 18' FE 450 17
    Yam wr250r - Suz DRZ400s - 2 Harleys
    LOL, bet that was a surprise! Never had it happen over the years
  5. Husky-Nut Husqvarna
    Connecticut
    1983 WR250, 2020 FE501
    1931 Indian 101 Scout, 1936 Chief
    You sure the bike doesn't have a Bultaco engine in it?
    :lol::lol::lol:
    ajcmbrown likes this.
  6. ruwfo Administrator
    NJ
    1985 250XC, 2016 FJ-09
    Would happen on my 86 400, from time to time, thank god only when I was trail riding, or my have soiled :D myself in a race
  7. oldbikedude Husqvarna
    Honey Brook Pa.
    Yup, a timing thing.
  8. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    my 88 250 more and more often until i swapped out the sem...it would roost the front tire
    oldbikedude likes this.
  9. dukkman Husqvarna
    Warwick Queensland Australia
    85/WR 400,86/WR 240,83/430 is mates
    69@71/TS90-76/TS100-72/DKW-78/PE
    Just fixed a Parcar golf buggy and they have 2 pickups one each side of TDC. You spin the starter one way for forward and the other way for reverse. Simple and smart setup.
  10. Zomby woof Husqvarna
    Ontario, Canada
    2011 CR 150
    This happened to me a few times on my Bombardier (Garelli) Junior Cross. It was always when I least expected it :banana:
  11. stormer254 Husqvarna
    England
    More than I dare let her know
    Yes!
    Happened to me a few times over the years with my Stormer and a Greeves ME I used to ride. Trying to leave the start line backwards!!
  12. toolie Husqvarna
    Ontario, Canada
    It wouldn't be so bad if it wasn't such a big surprise when taking off. It needs the reverse alarm like my sled:)
    I'm making a tool so I can check the actual ignition timing with my dial indicator.
    Other question is what is the actual husky spec for this bike with the motoplat mini6? Can't download any of the ref. manuals.
    TIA
    Bill
  13. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    I had the reverse running bulto Sherpa years ago...I got to the point where I could deliberately start it backward with a bit of a wimpy kick...won a lot of bets with that trick... I could tell if it was running backward as it used to" knock" a bit more than usual at idle.
    the first time it got me though..near rode into the next door neighbors po:eek: ol
    juicypips likes this.
  14. ct cr430 Husqvarna
    Connecticut , litchfield county
    1981 cr 430
    2007 honda crf450
    Happened to me also . Stalled going across a hill all rock and of course as luck would have it the kick starter was on the down hill side . That was the only time it happened so far .
  15. toolie Husqvarna
    Ontario, Canada
    So I was able to check the timing tonight and it worked out to be 2mm BTDC. Which according to an 87 430 spec'd at 2.3mm and a race set up of 1.9mm mine doesn't seem to be too far off? Any opinions? If I retarded it to 2.5mm would it make it easier or more difficult to start?
  16. justintendo klotz super techniplate junkie
    -if you moved it to 2.5mm you would be advancing the timing from your stated 2mm btdc. if you are not experiencing kickbacks, you could leave it as is.
    -what do you mean, "race set up of 1.9mm"? the more advanced, the more response, the more stress and octane requirement. a "race" setup would be book spec or perhaps even more advanced..
    -how are you measuring timing? in my 400 and 430 i have run 1.5-1.8 with little or no kickback.
  17. Crashaholic Husqvarna
    Antelope Valley, CA.
    73 450WR 6spd motor in a 75 MK frame
    The further away from TDC you move the timing the more difficult it becomes to start and the chance of kickback increases. According to my data your 2.00mm setting is spot on. There are other conditions that can cause the motor to pop and subsequently turn in the opposite direction. Whether its enough to ignite the motor in that direction is another thing but possible.
    Some of the things that come to mind begin with a slow piston speed from a weak kick start which are then combined with one or more of the following: a lean condition due to an air leak, low octane or old fuel, near empty carb bowl, intermittent sparkplug malfunction, ghostly spirits (sorry, I couldn't resist that one :D).
  18. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Had 360 start backwards it was due to water ingress in stator so yes timing.
    Couldn't for the life of me work that out at 3am in torrential down pour on a long distance trial, was running like a dog before it stalled..
  19. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    the alpina's massive flywheels would take it back over tdc if you wimp kicked it up to compression
  20. Kartwheel68 Husqvarna
    Newnan, Georgia
    Surprise hinted at the cause, kicks that dont spin the engine over fast enough to keep it going the correct direction when it fires.
