125-200cc is oem only option for 12t front sprocket?
Discussion in '2 Stroke' started by NWRider, Apr 2, 2012.
  1. NWRider Husqvarna
    I thought oem was the only option but am not positive. anyone else make one?
  2. Farmer John Husqvarna
    Santa Clara, CA
    2009 WR300
    92 WR250, 01 KTM 400MXC
  3. NWRider Husqvarna
  4. wallybean Mini-Sponsor
    Montana
    Mark,
    I have one that I will never use again. I will send it to you.
  5. NWRider Husqvarna
    Wow! Thanks Walt. I was going to run 13/52 but I have a WR250 chain that is almost new. It is 2 links shorter then the 125 chain so I think it will work with 12/49 which is the same ratio.
  6. CelticDude Historically Fast!
    x
    Walt is my BFF! :cheers:
  7. john01 Husqvarna
    Powhatan VA
    LOL Walt has a lot of those :applause:.
  8. CelticDude Historically Fast!
    x
    True enough, but how many other riders can say that Walt came to their garage and fixed their bike?
    :cheers:
    dartyppyt likes this.
  9. Kevin_TE250 Husqvarna
    Boise Idaho
    I'm a member of that club also....Walt's a great guy..:)
  10. chad26 Husqvarna
    eau claire,wi
    I found that renthal makes a 12 tooth frt for my 2010 250 TXC. Not sure how many splines are on the 125.
  11. R_Little Husqvarna
    NJ
    They do kind of look the same!
    I'd like to know.
  12. NWRider Husqvarna
    I am not sure and stopped looking but I do see that Motosportz list one. It does not state the brand but at it's price I assume it is not oem.
  13. Blakelpd5 Husqvarna
    Tigard, OR
    09 WRWB165
    I have a 12t from Motosportz... Don't know the brand, but it works! I wanna say maybe PBI
  14. NWRider Husqvarna
    I got the sprocket from Walt (thanks again) and it says Talon on the back so I guess that answers the original question.
  15. water racer Husqvarna
    http://www.knoxenduro.com Knoxville, Tennessee
    2013 Beta 250RR
    2009 Husqvarna WR125 1997 Fantic
    I paid big bucks for an OEM sprocket, also to answer another question the 250f and 125 are different, but just going from memory.
  16. CelticDude Historically Fast!
    x
    I also paid big bucks for an OEM sprocket and Motoxotica Dan said they were unique and only available from Husky. Since going to the 144 kit and the RB Designs carb mod I am now running a 13 tooth primary and a 54 tooth rear sprocket.
  17. R_Little Husqvarna
    NJ
    yes, one has a shoulder and one does not....totally different really.
  18. PowerKord Husqvarna
    Notheast Ohio
    2008 WR 250 Sold
    2014 Sherco SE-R 250
    Is it just me or do aftermarket front sprockets not fit as well? I just got a Supersprox front from Halls. I can barely get it on the shaft and then it seems that the retainer clip will also be a very tight fit.:thumbsdown:
  19. jbankes Husqvarna
    Nescopeck
    2009 WR144
    Watch running 12t's, Scott at Toy Tech said he's seen a couple bikes run the chain thru the front chain guide and into the swingarm itself by the swingarm bearings, I ran one for awhile but since switched to a 13t and am much happier with the gearing.
