Is this normal???
Discussion in '610/630' started by kewekenievial, Jan 8, 2010.
  1. kewekenievial Husqvarna
    Camarillo,ca
    610 TE
    KTM300xc
    [IMG] I had to take my fuel pump out, because the black wire came disconnected. Then I noticed that the screen seemed to be stuffed into my pump. It is connected to something, I didn't want to pull on it to hard. I was just wondering if this is normal???
  2. mtne Husqvarna
    Denver
    08' TE610 + 08'TE610 sumo'd
    KTM 950SE
    I think so. That's basically how mine looked when I pulled it out. I took the folded up end and fit it through the area under the filter.
    Be sure to double zip tie around the pump to make sure the clip prongs hold it in place.....
  3. kewekenievial Husqvarna
    Camarillo,ca
    610 TE
    KTM300xc
    Thanks for the heads up. Do you mean the hoses connected to the pump to double zip tie around?
  4. mtne Husqvarna
    Denver
    KTM 950SE
  5. kewekenievial Husqvarna
    Camarillo,ca
    610 TE
    KTM300xc
    t Thanks for the theard. That helps me out a lot.
  6. Rockchucker22 Husqvarna
    Bishop
  7. mtne Husqvarna
    Denver
    KTM 950SE
    I was just referencing for the issue where the fuel pump can come out of the clips and rise up in the tank. But your also right........ I think I can just see part of it in the second picture but not in the others...... :excuseme:
