JD Jetting- Power Surge 6X FI tuner for TE630
Discussion in 'EFI/carb' started by rjdenya, May 28, 2011.
  1. rjdenya Husqvarna
    USA
    2011 TE630
    05' Honda CR250R
    Hey guys,
    I just bought a JD fuel tuner for my 2011 TE630. I'm very happy with the pre-set options JD put in the device. I am a bit of a perfectionists so I couldn’t leave well enough alone [IMG]. After speaking with James from JD at length he encouraged me to test different settings to see what I liked. I'm curious if anyone has had time to play around with the settings and if so share their results. There are so many possible combinations to try its very time consuming. Also James said that his dyno testing was done on a stock bike with the "power up kit" only. That means a stock air box and exhaust system. The stock air box with snorkel seems restrictive but the size of filter and air box volume is plenty large.
    I have added twin Leo Vince X3 Enduro slip-ons and drilled four 3/4'' holes in the air box. I added fuel from the preset RED (3) to a richer (4) setting. It seems better but I want to test further. Other than the fact that I just want to ride!
    Chime in with what you've got!
  2. robertk61 Husqvarna
    Melbourne, Australia
    09 WR250
  3. husky666 Mini-Sponsor
    So California
    I have a SM 630 with a pipe and modded airbox, I used the settings JD gave me and it was much better. First I started to play with the red setting (main jet) it was 3 so I went to 4. Very little change so I went to 5 then 6 and that's where the magic happened. Since I ride it like a sportbike it loves the bigger main and it pulls hard on top, you can really feel it come in around 7000 rpm. Each full number adds 5% fuel in that mode so my increase was 15%. You wouldn't need that on a dirt bike beacause you can never hold the throttle wide open as long as you can on the street. I also changed the green from 3 to 4 (raise needle) and that cleared up a small hesitation off idle. I love the adjustability I have now, it's so easy and I can adjust it while I'm on a ride. You can see my thread in the 630 discussion.
  4. rjdenya Husqvarna
    USA
    2011 TE630
    05' Honda CR250R
    husky666, thanks for your input. My bike has twin Leo slip ons and an opened up air box. Since I stared this post I've had some time to experiment. I also added fuel in the mid (yellow) and red (high). You are correct that the engine now comes alive from 7,000 to the 8,300 red line. What a terrific device JD has created. Two thumbs up!!
    robertk61 likes this.
  5. rjdenya Husqvarna
    USA
    2011 TE630
    05' Honda CR250R
    My bike's setup, 2011 TE 630: Smog canister removed, power up kit, twin Leo Vince Enduro slip-ons, JD Jetting FI tuner, 9 x 3/4" holes drilled in the air box and oem snorkel removed. I used an Innovate Motorsports DB gauge (along with seat time) to achieve what I feel is the best air fuel ratio setting possible. I also have a 14 tooth front sprocket and Pirelli MT-21's front and rear. My bike will currently reach a top speed of an indicated 101mph on the speedometer. BTW, it would not go over 90 mph with stock tires, twin Leo's and the power up kit. First and second gear wheelies are easy, third gear requires some effort but once up I can switch to fourth while going :).
    The bottom line with the Husky 630's is they are completely choked from the factory. It has been discussed at length here on this forum that the 630 engine has such great potential. Give her more air, fuel and exhaust flow...and believe me, the bike is transformed. Comparing a bone stock 630 to how my bike is set up now is like riding two different bikes. Power wise to me, it's like driving a Suzuki DRZ400S (I had one and liked it) and then getting on a KTM530 EXC (friend has one and its awesome). Driving a stock bike with the crazy air box maze and without a power up kit is not only disappointing but dangerous...for the bike and rider. Bolt on an exhaust, open up the air box and add a JD tuner. You will have a different bike.
    My final JD settings:
    Green- 3
    Yellow- 7
    Red- 7
    Green/ Blue- 1
    Yellow/ Blue- 2
    Red/ Blue- 6
  6. Suputin Husqvarna
    2011 SMR 511
    WR250X, 81 Yamaha RD350LC, 90 RZ350
    Been playing with my new JD tuner and it wasn't the night and day change I had been expecting.
    The bike def has more midrange power. It will now loft the front tire in first from power alone. However the effect on the top end hasn't been so impressive. The motor seems to rev a bit more freely but there still seems to be little power up top.
    My settings are a bit closer to stock at this point. I have tried going significantly richer and it didn't seem to make much difference.
    The bike def runs cooler which is a major improvement at this point.
  7. oregonsage 4st Clerk
    Dry Washington
    FX450
    Yamaha DT400 x 2, BMW G310R
    Youre running a 511? I know that Kelly reported on dyno runs at JD Jetting which indicate that there is quite a bit of top end taper off due to restriction.... Would be interesting to see if adding some airbox inflow would help... since mine is dirt only this is of little consequence to me, but I bet the TE/SM guys would love some more top end.
  8. Motosportz CH Sponsor
    Run the red zone way up to like 7 or so and see if it revs out further. Mine gained a TON on top (2011 TE511) although this does not do a lot for me as i normally short shift and do not bounce off the rev limiter so most my power use is below this range on this bike.
  9. rjdenya Husqvarna
    USA
    2011 TE630
    05' Honda CR250R
    What bike do you have? Do you have a stock exhaust? Air box opened up? Just adding fuel is only part of the equation.
  10. Suputin Husqvarna
    2011 SMR 511
    I am running a 511 SMR with the stock pipe. I did drill a pair of 1.5" holes in the front of the airbox cover to increase flow into the airbox.
    I tried the Red Zone set at both 4 and 7 and it actually felt a bit better set at 4 but there is really not much difference between the two settings.
    One thing I forgot to ask. I have the Race Map II plug installed which IIRC richens things up across the board? Wonder if it might work better with the race map plug removed and the JD Tuner set richer?
  11. rjdenya Husqvarna
    USA
    2011 TE630
    05' Honda CR250R
    There are three parts to consider for increased engine power. More air, fuel and exhaust flow. There will come a point where you cannot add any more because the engine will be maxed out and no longer gain power. If you want try a slip on muffler or gutting your stock can. The TE's stock muffler has a restrictive catalytic converter. I'm sure some TE511 owners will chime in and help.
  12. organ donor Husqvarna
    Berlin
    The airflow on the 630 is restricted by the air box lid snorkel. The only air that can get in is from the snorkel opening which is behind the plastic fairing (this is easy to see with the oval black dirt smudge on the foam filter). So the only way to get more air in seems to be by cutting a hole in the air box lid. Have just received the EHS filter and am fitting that together with a fine wire mesh cover for the gauze filter. Will then try increasing fuel with the JD box.
    jtemple likes this.
  13. Suputin Husqvarna
    2011 SMR 511
    Once winter hits I will have a look inside the OEM muffler. Not gonna do that right now cause it requires drilling out all the rivets holding the can together.
  14. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    2013 Kawasaki ZX-14R
    I'm considering doing the same thing and am waiting for a report!
  15. rjdenya Husqvarna
    USA
    2011 TE630
    05' Honda CR250R
    The EHS should work well installed just in front of the throttle body intake (as pictured a few posts up.) I know you expressed concern with water and or snow ingestion in the air box. The water resistant membrane on the EHS should do the trick. When you do have it installed turn your JD tuner up to 7 in mid, (yellow) and high, (red.) The engine will perform a lot better. Each number after 3 with your JD tuner is a 5% increase in fuel. So that's a 20% increase in the mid and high fuel range. My bike runs like a champ with those settings and yours should too.
    James from JD Jetting personally helped me along with tuning my TE630, In fact my drilled air box is pictured on his web site.
    You have the twin Arrows and ecu setup so I am very interested in your performance gains. Keep us posted!!
  16. organ donor Husqvarna
    Berlin
    Will do! That was a VERY fast delivery all the way from the U.S. of A! (But am now waiting for delivery of bling black anodized pan head bolts from the UK for the frame)
    PS
    Took the airbox lid off last night and saw that where the air intake snorkel fed air into the airbox there´s a black smudge of dirt on the air filter showing how the snorkel severely restricts air intake. Cutting the aperture for the EHS frame will definitely provide a relevant increase in the air intake.
  17. Suputin Husqvarna
    2011 SMR 511
    Anyone know if it is better to run the original map or the "Race Map" in a 511 when using the JD tuner? Right now I have the race map plug installed.
  18. organ donor Husqvarna
    Berlin
    Have now installed the EHS frame and put in a fine wire mesh over the membrane for added protection. (used the bolts supplied in the package as I didn´t want to wait for the bling dome head black anodised bolts ordered in the UK). All I´ve got to do now is understand the complex instructions on how to come to terms with the row of blinking LEDs to set the added fuel flow. Started last night and had to give up so as not to frighten the neighbours.
  19. Motosportz CH Sponsor
    Run the JD with the power up wire installed.
  20. organ donor Husqvarna
    Berlin
    630SM
    Twin Arrows + EFI
    p/u plugs
    JD Jetting
    EHS airbox kit
    Slipper clutch
    The airbox cover doesn´t look too bad. Think I should have got the frame in black (only saw it in the list after ordering). Don´t need a dyno to tell me that the power has increased dramatically over the whole rev range.
