hey just bought a power surge to my husqvarna 310 te 2009 and wondering if there is someone sitting on some good settings? since I find them by jd does not work so well it would like to die when you turn on the gas out a curve and then I wonder if there is anyone used the 12 Holes injector on a 2009? and if it makes any difference thanks
I was looking through this just last week, found severeal notations that people has made for the settings on the JD. For me on my 510, I used all the setting that came with the unit, then found that the last one, on the accelerator pump was up on 6, once I started tunring ot down to 3, it ran so much better. But look oer all teh posts, they will help you out.
http://www.cafehusky.com/threads/jd-jetting-power-surge-6x-fi-tuner.16081/page-6 I don't think it is worth the cost to change the injector on our model. Btw there are a range of settings listed on the link I inserted but chances are that the stock Jd settings won't work because the bikes existing settings are already richer than baseline. You could first try lowering the blue/red accelerator pump down to 0.5-1 and see if that works.
