JD Jetting Tuning levels and how to adjust properly
Discussion in 'EFI/carb' started by Stoyan, Jun 20, 2017.
  1. Stoyan Husqvarna
    510 SMR 08
    Hi guys,
    What are the RPM levels for low, mid, high range of the JD Tuner settings?
    What is the best way to adjust the AFR without an AFR gauge? How can I feel when to add and when to remove fuel?
    Thanks,
    SK
  2. Slider Husqvarna
    Perth W.A.
    TE510 2009
    Kawasaki ZX12R 2003
    Trial and error. Standard setting is slightly lean and corresponds to position 3 for each setting on my 09TE510.
    Bogging or lacking power/response may benefit by adding fuel slightly.
  3. Slider Husqvarna
    Perth W.A.
    TE510 2009
    Kawasaki ZX12R 2003
