Jetting - '08/'09 TXC 250?
Discussion in 'EFI/carb' started by fitness2go, Nov 20, 2009.
  1. fitness2go Husqvarna
    Seattle WA
    I realize there is a JD Jet Kit, but what is everyone running?
  2. MotoXotica Husqvarna
    Vacaville
    i installed a jd jet kit,put low elevation needle in 1 position leaner than suggested.i have a 42 pj.i also have one of the adjustable leak jet things on it.not saying its perfect but it had a big bog stock.dan
  3. jmetteer Husqvarna
    Woodland, WA
    TXC300 CR125 CR144
    WR250F, TRANSALP
    I am running...
    the JD red needle in the 4th slot down from the top
    42 pilot (stock)
    185 main
    55 leak jet (I think that is what was in the kit)
    thick o-ring on the AP arm
    zip ty fuel screw tuned for the conditions
    The JD jet kit came with a 45 pilot, but the instructions said to install a 42 and 42 was stock. I ran the 45 pilot at first but it was too rich and it didn't start all that well. The 42 is the way to go.
    I started my bike one time before installing the JD kit...
    Later,
  4. Motosportz CH Sponsor
    David, did i miss something? Did you get a TXC250?
  5. fitness2go Husqvarna
    Seattle WA
    ...hmmm. No such thing as surprises with you...I guess I was pretty obvious...what with asking jetting questions and all. I'm prepping the bike as we speak...lubing the linkage, swingarm pivot & head, changing crossover tube, installing Uptite Y, installing TT Vector with temp gauge in the radiator hose, putting in a TurnTech 2.5 battery, applying anti-seize to the chain adjustors and mudflap bolts, applying loctite, going over the bike with a torque wrench (especially triple clamp bolts)...you get the picture. I need to ride with you for side-by-side comparisons! 2009 TXC 250 vs 2010 TXC 250. I can't already tell a huge difference in weight between it and my 08 TE 450.
  6. jmetteer Husqvarna
    Woodland, WA
    TXC300 CR125 CR144
    WR250F, TRANSALP
    We may as well do an 08, 09, and 10 comparison ride.
    :thumbsup:
    Later,
  7. fitness2go Husqvarna
    Seattle WA
    I forgot about that...the whole family of TXC 250's!
  8. fitness2go Husqvarna
    Seattle WA
    I was not looking to get a new bike for at least another year. I wanted the 2010 250's to get a solid year of seasoning and on the bike set-up with real riders from this forum. Well stupid me...I was browsing the net and came across a deal that I couldn't say no to. That coupled with everyone's rave reviews including and especially from Jake and Krieg (the one handed kickstart with the beer on the seat was classic). It didn't help that I rode Jake's bike and was floored at the difference between an '08 TXC 250 and '08 TE 450. I also rode Russ's TE 310 and that sealed my fate...smaller is better for me!
    Out of the box jetting is terrible! It will barely stay running without the continuous use of the cold choke and/or significantly turning up the idle. Also, I'm getting some tail smoke with the cold choke on.
    Wow, is the air screw impossible to get to and adjust or what? I had to loosen the boot and twist the carb to see what I was doing and to get small flathead screw driver to it. Zipty here I come!
    So here is what comes stock:
    175 Main (main jet)
    42 Pilot (Husky calls it an idle jet?)
    72 leak (Husky calls it a starting jet?)
    200 Main air jet (what the heck is that?)
    Throttle Valve 15/M (I have no clue)
    Stock needle in the 4th position from the top
    Air screw 1.5 from closed
    Low air jet 100 (??)
    And here is what I should do - JD Jetting kit:
    185 Main
    45 Pilot, but keep it stock at 42
    55 leak
    special tapered needle in the 4th position from the top
    What about the air screw?
  9. jmetteer Husqvarna
    Woodland, WA
    TXC300 CR125 CR144
    WR250F, TRANSALP
    That sounds almost exactly like mine ran with the stock jetting.
    I wouldn't buy the Zip ty fuel screw again, or any aluminum fuel screw for that matter.
    Get a brass one from merge racing, or any other company that makes them.
    I had the zip ty laying around from my WR250f, that is the only reason I used it. It is better than stock though.
    Later,
  10. fitness2go Husqvarna
    Seattle WA
  11. jmetteer Husqvarna
    Woodland, WA
    TXC300 CR125 CR144
    WR250F, TRANSALP
    That is the one. :thumbsup:
    Later,
  12. HomeFinance Husqvarna
    Congradulations on the new ride. Might as well add a 300 kit. I heard Motosportz has a deal on them.:thumbsup:
  13. jmetteer Husqvarna
    Woodland, WA
    TXC300 CR125 CR144
    WR250F, TRANSALP
    I, uh, heard that as well...
    Later,
  14. Motosportz CH Sponsor
    Awesome David :thumbsup: I knew with all your chatter about that bike you would end up with one some day soon. Nice. Did you keep the TE450?
    camparo coming up. :cheers:
  15. HomeFinance Husqvarna
    Where's the photo's ?
  16. krieg Husqvarna
    Matthews, NC
    Many in the past
    '12 Triumph Scrambler
    That would be the fuel screw. Air screws are for 2 strokes.
  17. fitness2go Husqvarna
    Seattle WA
    I just looked through the goodies box and it also has:
    170 and 180 Main
    40 and 45 Pilot
    I guess it's a moot point anyway, as I ordered the fuel screw and JDJetting kit.
  18. fitness2go Husqvarna
    Seattle WA
    I'm such a newbie...:lol:...my only defense: Husky calls it that in their workshop manual.
  19. fitness2go Husqvarna
    Seattle WA
    Not a bad looking bike.
  20. HomeFinance Husqvarna
    Sweet! When do we get a ride report ?
