125-200cc Jetting issues with the TMXX - aware of the jet block gasket failure?
Discussion in '2 Stroke' started by jeanjean, Jan 8, 2019.
  1. jeanjean Husqvarna
    Netherland
    WR 125
    IT175H
  2. hesutton Husqvarna
    Kentucky
    2014 WR300 (SOLD)
    2021 Sherco 300SE 2002 Honda CRF450
    KTM Talk won't let non-members view the page linked above.
    Is there some way to paste the pertinent information here?
    Heath
  3. Picklito Husqvarna
    Washington
    430, 430, 430, ,400, 175
    KTM250xc, KTM500mx, KTM440exc
    I started that thread. There is a rubber gasket under the jet block that has been failing. It appears to be squeezing out and messing up the idle/off-idle circuitry. It may well be why some riders love the Mikuni while others can't get it to run worth a darn. My own 150xcw ran very will with just the usual jetting, then began getting funky after several months. A carb teardown showed that the jet block gasket had failed. The part is not shown on the fiche so no way to order it. I fixed it (made my own) and the bike ran well again. Several of us on KTMtalk have been working on solutions that don't require a homemade gasket, and Cometic agreed to produce a replacement. There is now a rubber-metal-rubber replacement available from Cometic. These pics show what was in my carb when it was acting funky.
    David Hudson and lankydoug like this.
  4. jeanjean Husqvarna
    Netherland
    WR 125
    IT175H
    I assume that as the japanese bikes sharing this carb, the HVA's have the single-hole-design and the gasket doen't fail as fast as by the KTM's.
    jeanjean
  5. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    Glad to hear that an aftermarket company has stepped up to help.:cheers:
    I hope they will show a part number for it on their website soon.
  6. Oldscool Husqvarna
    South Australia
    None
    RM125, SWM RS500R & Superdual
    Picklito, that's a great find. Thank you for sharing it.
  7. Picklito Husqvarna
    Washington
    You can buy the prototype now, available 10, 14, 20 thou thick. It's looking like the 0.014" will be the way to go, as most of the jet blocks are recessed .010-.011":
    CB559010RC
    CB559014RC
    CB559020RC
    The other VERY common failure in the Mikuni is the O-ring for the float needle seat. It shrinks, cracks, then leaks and your fuel level is too high. Check it out!
    Borntoride71 and lankydoug like this.
  8. Dirtdame Administrator
    Rock Springs Wy
    17 Beta Xtrainer
    O ring failure has been an issues for decades on various Mikinis.
    Picklito and lankydoug like this.
  9. lankydoug Husqvarna
    MO
    WR
    TM 300en
    O ring failures as well as gasket failures became common since ethanol showed up in the fuel... so yes a really long time.
  10. Treesmacker Husqvarna
    2010 CR150 "Woods set-up"
    YZ125
  11. Borntoride71 Husqvarna
    Spain - Castilla y Leon
    2008 TE 250 EU Gone...
    2007 WR 250
    Hi There,
    Does this apply to the 2012 wr 300 ?
  12. Picklito Husqvarna
    Washington
    It would apply to any Miknui of same design, but we oddly hadn't heard much about it until KTM/Husky released the 17's with Miks. Can only speculate why that would be. I've now installed several of the Cometic gaskets with no further issues.
    Borntoride71 likes this.
  13. jeanjean Husqvarna
    Netherland
    WR 125
    IT175H
    JAM likes this.
  14. PaulD Husqvarna
    Little Egg Harbor N.J.
    2010 wr250( sold)
    Triumph Sprint RS. Honda TRX300EX Be
    Finally got around to checking mine. Yup gasket was bad. Also found my main jet laying n bottom of bowl! Explains the sudden massive spooging issue that developed at the end of last ride. Blubbering bad at WOT. Will take her ouT tomorrow for a test run. 20190420_141009.jpg
