Jetting specs for 08 TXC 250 with 300 big bore kit
Discussion in '4 Stroke' started by Wildman, Jan 3, 2010.
  1. Wildman Husqvarna
    New Zealand
    Hi, Just wondering if anyone knows, if after fitting an Athena 300 kit to TXC 250 (carb) if the jetting needs to be altered at all.
    Cheers
  2. jmetteer Husqvarna
    Woodland, WA
    TXC300 CR125 CR144
    WR250F, TRANSALP
    I did not touch mine other than a fuel screw adjustment. Mine is set up per the JD jetting kit instructions.
    Later,
  3. Wildman Husqvarna
    New Zealand
    Thanks for that. It seems to be running ok, just thought at first ride (after kit was installed) it was pinking a little under heavy load, but I havent noticed it since then. Love the low end now though;-)
    Cheers
  4. fitness2go Husqvarna
    Seattle WA
    Where did yours end up at? 2 turns out?
  5. jmetteer Husqvarna
    Woodland, WA
    TXC300 CR125 CR144
    WR250F, TRANSALP
    I am not sure off the top of my head.
    I did lean out the needle one slot when we went to Moab and I left it when we got back. It runs a bit crisper, I get some lean pops with the SA out and it is really close to perfect with it in.
    Later,
