250-500cc JP weld on busted radiator tab
Discussion in '2 Stroke' started by R_Little, Apr 29, 2013.
  1. R_Little Husqvarna
    NJ
    Common problem I'm sure...
    The upper shroud bolt tab snapped off and the shroud is flapping in the breeze.
    Will JB Weld make a suitable repair?
    I want to fix it before the lower tab goes away too.
    Thanks
  2. jimf Husqvarna
    scotland uk
    husky 125 sm
    na use lumiweld that stuff u heat with a propane torch good stuff I use it all the time jp weld is sorry complete and utter crap in my opinion if it came down to jp weld and duck tape I would use duck tape
  3. Idacurt Husqvarna
    hailey,ID
    07 WB177
    Scorpa 175
    I had the same issue and attached a little steel tab with a sheet metal screw right through the aluminum side of the radiator.Two years, lots of crashes and it's still going strong.Pre drill the hole in the tab for the shroud first and don't use a long screw that will damage the radiator.
  4. icebergstu Husqvarna
    South Australia
    WR300/TE610e
    WR360 CT110 XR100
    On my last trip away we I cracked the core in the very top corner of my rad.
    Pulled the fins out around it which also put holes in the core too.
    JB welded it up and left it for about 2 hours.
    Done 30 hours since then and no probs.
    AWESOME STUFF!!!
    Stu
  5. R_Little Husqvarna
    NJ
    I JB welded it last night and I'm going to rivet a reinforcement out of aluminum sheet over it.
    I see the point about using a short screw if you screw it on.
  6. wait4me Husqvarna
    Orange County, CA
    11 WR300
    85 YZ490 "Ol Bessy"
    I have used JB Weld for years with very good results. Have had BAD results with the JB Quick.
