JT Front Sprocket Issue
Discussion in 'TR650' started by kwb377, Jun 29, 2015.
  1. kwb377 Husqvarna
    Birmingham, AL
    '06 TE610
    Versys 1K; 'Berg FE390; KTM 200 XC-W
    Replaced my stock countershaft sprocket this evening with a 15t JT sprocket. Once torqued and chain adjusted, I gave the wheel a spin to check everything out. I noticed it makes way too much noise...sounds like the chain is hitting the case, although once I removed the sprocket I couldn't see any marks on the case from rubbing.
    Anyone else have issues installing a JT sprocket?
    View: http://www.youtube.com/watch?v=umaXefXbEJw&feature=youtu.be
  2. isldtime Husqvarna
    Symsonia, Ky.
    2013 TR650 STRADA
    2002 Ural Tourist
    Look at the lower mounting bolt ( chain hitting the tip ) for the foot peg. You might have the sprocket flipped the wrong way . Can't remember which way it goes.
    nycrider likes this.
  3. nycrider Husqvarna
    Aprilia Dorsoduro 750, Suzuki DR650
    The "jtf402-15" etch is suppose to be facing the outside. It appears his is facing the inside.
  4. kwb377 Husqvarna
    Birmingham, AL
    '06 TE610
    I checked this morning, and the footpeg mounting bolt was protruding just enough to make contact with the link pins.
    Is the flange supposed to face toward the case, or to the outside? The sprocket I removed (installed by previous owner) had the flange facing inward.
  5. kwb377 Husqvarna
    Birmingham, AL
    '06 TE610
    After googling 650 Rotax images, I confirmed that the flange was supposed to face inward. Flipped the sprocket and all is well.
    Now for a test ride...
    Thanks for the assistance! :thumbsup:
  6. kiwiape Husqvarna
    650 Terra
    Aprilia DD750
    I can confirm you have the off-set round the wrong way. I recently put JT's on F & R and no problems.
