Just a few Questions. EFI !! First time Husky owner !!
Discussion in 'EFI/carb' started by OP_9, May 22, 2010.
  1. OP_9 Husqvarna
    Ohio
    I have been reading all the post here on the EFI. I just purchased a 2010 TXC 250 which is in route from the distributer. I have not asked the dealer yet on any issues with the EFI. I thought I'd hit up the true experts on here first. I guess the first question is will this 2010 have the most recent flash and will it be effective? Second, power commander just finished their application with an optional auto tune. Are these worth the cost? Third, once you start with either the ibeat, and power commanders how sensitive are these bikes once there programed? I guess I am just hoping that I don't have to tweak this thing everytime I ride. But at the same point I don't want it to fall on it's face 20ft short of a take off so to speak. And finally will this thing come with restrictions? Spark arrester, throttle stop etc.. Give me some updates !! Thanks
  2. seymore Husqvarna
    Boise, ID
    Welcome aboard OP_9!
    As far the latest ECU firmware, maybe someone can post the different revision numbers that are shown in iBeat. With that info, the dealer can connect iBeat and verify if it's the latest. If it's not I would suggest you have the dealer perform the re-flash at sometime.
    The first thing your going to need to do is get about 500 miles on the engine to loosen it up before you start to make too many assessments on performance.
    As far as iBeat vs. PCV, some have had good luck with iBeat making the adjustments to the 3 fuel map settings without the need to add on the extra hardware of PCV & AT. Others have been happy with adding the PVC with and without AT. Within the next month I'm going to have the opportunity to test a 2010 TXC 250 with iBeat and add PCV & AT. PCV can do things that iBeat can't and iBeat can do things like TPS calibration and error code reading that PCV can't. If you a have good dealer support and they're not too far away, you may not need to have your own iBeat setup.
    With either solution, once you find the right settings you won't need to be readjusting unless you just like to tinker.
    I Know this doesn't answer all you questions, but after you get time on the bike I'm sure you will even more.
    I think your most important concern is about the dealer making sure the ECU is updated since it appears to have fixed the off-idle-1/4 throttle issues.
  3. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
    Glenn Kearney took 3rd in the latest GNCC on a 2010 TXC 250. This bike has moved him nearer to the top riders. So, yes it works.
  4. OP_9 Husqvarna
    Ohio
    seymore,
    Thanks, I appreciate all your knowledge there. I will give an update here once I get some time on her.
