Just a thought
Discussion in 'TR650' started by isldtime, Mar 10, 2014.
  1. isldtime Husqvarna
    Symsonia, Ky.
    2013 TR650 STRADA
    2002 Ural Tourist
    Has anyone tried to do an idle relearn???
    I'm on my 3rd. EFI MC.
    The 1st was a 2007 Triumph Tiger 1050. guilty of lean surge and abrupt throttle response. solved with the "Booster Plug".
    2nd was my 2009 H.D. XR1200. Lean surge and stalling at stoplights and stumble on accel from stops. Cured with a "Patriot Top Fueler" piggyback adjustable device.
    Well I got thinking about my Tiger and the throttle relearn so I tried it tonite on my new Strada.
    I won't know how good it really did but after the procedure it sat for about an hour then restarted.
    The idle was stable at 1500 rpm and no matter how I blipped the throttle it came right back to 1500 rpm.
    Anyone else?? :thinking:
  2. RidingDonkeys Husqvarna
    Paso Robles, CA
    TR650
    How did you go about this process?
  3. isldtime Husqvarna
    Symsonia, Ky.
    2013 TR650 STRADA
    2002 Ural Tourist
    On my Tiger1050: From fully cold start the engine but do not touch the throttle, let it idle till the fan kicks on then for 15 min. shut ign. off all without touching the throttle. I won't know if it worked till this weekend. But I did order another AIT sensor to do the "Eruption" mod.
  4. Dan Keifer Husqvarna
    New Britain CT
    2017 701 Supermoto
    I tried that before I installed the eruption just to see if it had any effect because someone suggested it somewhere on the eruption thread. It had no effect.
    Keep in mind that the stalling problem only shows up while riding. You will come to a stop and the bike stalls - you will come to a rolling stop and the bike stalls. You will definitely know if you have this problem - it is both annoying and dangerous.
  5. RidingDonkeys Husqvarna
    Paso Robles, CA
    TR650
    I can't say that I've had an issue like that. I do know that when cold, the bike sometimes stutters when I twist the throttle. If I crank it and let it idle while I throw on gloves/helmet/etc, then it has a chance to warm up to one or two bars, and then I have no issues at all.
  6. Baddrapp Husqvarna
    Yucca Valley
    TR650
    I had the stall happen to me twice while turning onto a side road. luckily their was no one behind me at the time, I just popped the clutch and bump started the bike. I installed the Wukka King spoofer and all is good. I have never had a stall since.
  7. PaulC F class
    Bayside Brisbane, Australia
    TR Terra
    Same Same , and can be downright f%#ken dangerous, about weekly! I think at this lean end it could be related to fuel quality (for some TRs).
    I installed a BP 4 months ago and all has been good since!
  8. Next Strada Demolitionist
    Brevard, NC
    We used to call this the 10 minute tune up. Start it and let is cycle through at least two fan kick ons without touching the throttle once. This can be extra fun on these bikes if you are hunting for neutral with the kick down :)
    I love my Wuka plug, but found my pipes were getting a little sooty with it cranked to full. Turned it down a few days ago and have found it to be less awesome... might need to do a 10 min tune up with the wuka on the lower setting?
  9. kyle01 Husqvarna
    Chicago il
    TR650
    Beta 430, Honda CR 144, XS650
    Just do the eruption mod... Instant success for me and super easy. And cheap.
    bikehunter likes this.
  10. isldtime Husqvarna
    Symsonia, Ky.
    2013 TR650 STRADA
    2002 Ural Tourist
    A new A.I.T. sensor is in hand (to cut up) and the thermistors will be here tomorrow!!
  11. msmith345 Husqvarna
    Shawnee, KS
    '12 WR250, '92 360, '80 390
    '72 Yamaha R5, '17 SV650
    Eruption works. It's cheap. It's pretty easy. But as in the other thread, it's not perfect.
  12. Next Strada Demolitionist
    Brevard, NC
    The Wuka Plug set to high make the TR fueling pretty much perfect, for me. I noticed a bit of soot in the pipes (after 1000+ miles at full tilt) and decided to turn it down a notch. My complaints with it turned down were on a cold morning (30ish), and only in the first 1-2 miles.
  13. bikehunter Husqvarna
    Hampshire
    Strada 650
    Harley, bmw, moto guzzi
    +1 on that
  14. isldtime Husqvarna
    Symsonia, Ky.
    2013 TR650 STRADA
    2002 Ural Tourist
    Eruption mod in done and installed. Will go for a ride tomorrow...
  15. drzcharlie Husqvarna
    isldtime, you will like it. I found today that the snow flake symbol goes away at about 60* F. My temp gauge stated it was 40.1* F. I just finished the air box/air filter mod and all I can say is the bike is perfect now. I love it.
    mag00 likes this.
  16. mag00 Husqvarna
    Tucson
    Terra, Strada
    XR250 R1100RS CH50
    Do you have the single can conversion yet? :thinking: maybe almost perfect.:oldman:
  17. drzcharlie Husqvarna
    I intend to keep both cans. I like the aesthetics. They are de-catted.
  18. isldtime Husqvarna
    Symsonia, Ky.
    2013 TR650 STRADA
    2002 Ural Tourist
    Went on 2 short rides yesterday. No stall or stumble. Well worth the time and money!!
  19. rww Husqvarna
    Kennewick Washington
    tr650
    Ducati, Cagiva Kaw Zuki Honda
    I have been running the Wuka King set up and then went to the Eruption set up.......supper smooth...very very nice
  20. AUS_TR650 Husqvarna
    Australia
    2008 KLX250S
    What was the reason for changing over?
