Just Bought A 2013 Tr650 Stada. I Feel I Was Conned. Stalling And Other Issues.
Discussion in 'TR650' started by Pchap00, Apr 17, 2022.
  1. Pchap00 Husqvarna
    CA
    None
    Bought a 2013 husky tr650 strada. I wasn't able to take it on the highway because I wasn't comfortable being the heavy traffic with a bike that wasnt mine.
    I was told there wasn't a single issue with the bike other than it may need tires soon, which was obvious. It started stalling out. It would get to higher rpms and it would stumble. I almost dumped it because of the stall. I put new gas in it, new oil, new plugs, and changed the air filter thus far.
  2. shrubitup Husqvarna
    Seattle WA
    probably a clogged fuel pump, fuel filter, or fuel injector
    Pchap00 likes this.
  3. PaulC F class
    Bayside Brisbane, Australia
    TR Terra
    Unmolested there a good horse!
    How many K's?
    Pchap00 likes this.
  4. mag00 Husqvarna
    Tucson
    Terra, Strada
    XR250 R1100RS CH50
    Got any pictures?
    Pchap00 likes this.
  5. sussurf Husqvarna
    Port Macquarie area, NSW
    Triumph Sprint 1050, Daytona 955i
    Clean IACV
    Pchap00 likes this.
  6. AlecR6 Husqvarna
    I recommend putting a ground wire on the ECU also. I had an issue with misfiring and a CEL in the higher RPMs, running a ground wire from an ecu case screw to the negative battery terminal fixed it. Also provides some safety from accidentally shorting the ECU and bricking the bike.
