Just got my bike. EWS?
Discussion in 'TR650' started by boytal91, Nov 7, 2014.
  1. boytal91 Husqvarna
    2013 TR650 Strada, 2006 610SM
    Hey guys just got my bike tonight. and i have one key the guy is sending me the other. I charge up the battery and I tried to start it and the dah just says ews. any ideas? the bike is brand new i took it out of the crate.
  2. nev.. Terrarist
    Greensborough, Australia
    '13 TR650 Terra
    '14 XT1200ZE
    I'm curious why you have a new bike in a crate and "the guy" has one of the keys?
    I'd start with the electrics. Ensure the battery has a good 12v+ charge and then check electrical connections. The ECU, the dash and the ignition are all related to the immobilizer. A bad connection or a not quite clipped in 100% plug could cause the error. Pull all the fuses and reseat.
    richard kersten and Cosmokenney like this.
  3. boytal91 Husqvarna
    you forgot to send one it'll be here today.check the fuse box under the seat is there another box because those are good and I already charge the battery I checked everything I could see I don't see any issues
  4. boytal91 Husqvarna
    He forgot to send one it'll be here today.i checked the fuse box under the seat, is there another box because those are good and I already charge the battery I checked everything I could see I don't see any issues. PS disregard last post I'm on a phone i don't know what happened
  5. Greg Jetnikoff Husqvarna
    Bundaberg Australia
    BMW F80R
    EWS code is usually the ECU security ring coil sensor around the ignition key OR the keys you have are not programmed for the ECU you have ( they are individually matched and can be reset via the MOSS, I think). Check that the connector from the ring coil ( black plastic thing around the ignition lock) is connected properly. It lives in the headlight. DO NOT PULL THE WIRES GOING TO THE RING SENSOR. The sensor is very brittle ( as I found out) and WILL break the wire/coil connection)
  6. drzcharlie Husqvarna
    The plug he is speaking of is here:
  7. Baddrapp Husqvarna
    Yucca Valley
    TR650
    From the research I have done is the moss tool can remove/block a key from working. But the ecu has a set number of key codes. Once the codes are all used the ecu is locked. It requires a new ecu for additional key codes.
