Just Got New Te 630.. Need Advice.
Discussion in '610/630' started by Carsondriver, Aug 21, 2011.
  1. Carsondriver Husqvarna
    Folks,
    Just picked up a new te 630 and need some advice. I have heard stories of nuts/bolts coming loose and that I should use threadlocker. Can somebody tell me which nuts etc are prone to coming loose and need the threadlocker?.. good descriptions needed for me to understand.. somewhat challenged when it comes to finding parts!!.. pics would be very helpful for what is what!!.. thanks for any help.:)
  2. MrClean Husqvarna
    So Cal
    Sprocket nuts/bolts!!!
  3. LRPct Husqvarna
    NW connecticut
    Really the best way to get acclimated to your new machine is to take a lil time.. Maybe a lil less than an hour with tank on to check the snugness of everything, front to back. Maybe a lil more than an hour if you take the tank off and get those under there, upper motor mount etc. Take your time, enjoy it.. :)
    ohh. and yes. LOtite the sprocket bolts. Never came loose with it for me, and still have no problem busting them loose for sprocket changes.
  4. Busted RS Husqvarna
    Perth, Western Australia
    2011 TE630, WR300 '09
    DT360A's
    Good idea to check tightness of the two Ignition key screws also. Better you remove, add some "222" Loctite or similar and refit. Important to use the correct torque values all the bolts/screws etc.
    Hope you enjoy your bike as much as I do mine, great machines.
    Power on regardless :D
  5. oneleven Husqvarna
    2011 TE 630
    I've had bad luck with the left side subframe bolt. Even with blue loctite they just keep vibrating loose. ymmv.
    Offtopic: check your chain guide tabs that are welded to the swingarm. Are they inline with your chain? I just checked mine today for the first time while installing a guide and it was way off. Had to use three washers to compensate.
  6. willie Husqvarna
    NS Canada
    TE 630
    The blue stuff is a low strength locker. Try the red 263 never come loose till you die maybe even longer thread locker.
  7. sethro Husqvarna
    flagstaff AZ
    all the things mentioned above were loose, the spokes were also very loose on my bike
    Sethro
  8. oneleven Husqvarna
    2011 TE 630
    Okay, guess it's time to try the red stuff. Hopefully I won't need to unbolt it in the future. thanks!
  9. tropicoz Husqvarna
    If you do, just use a fine tip butane torch to heat the head of the bolt and it'll come loose!
  10. WhiteAndRed Husqvarna
    I was a little worried at first, but everythings still tight. Had a close eye on the sprocket bolts. Still tight.
  11. RDTCU Husqvarna
    '11 630SMS
    Same here, only thing that's worked loose in 1100 miles was the lower, longer of the two bolts holding the front sprocket cover and case protector on. It disappeared at about 600 miles, and I replaced it with a new one from the parts bin at the local dealer.
  12. CJBROWN Husqvarna
    Orange County, CA
    '15 R1200GS
    1. Foot peg bracket bolts. Remove and locktite. Blue okay.
    2. Change the oil sooner rather than later. Then do the full service at 1000 mi.
    3. Set race sag, will handle better all around and eliminates any headshake at speed.
    4. Check suspension settings, set to factory clicks to start.
    5. Install a skid and guards for any off pavement riding.
    6. Check headlight aim before you have to ride anywhere in the dark - mine was WAY too high. Front number plate pops off to access adjust screw. Point the bike at your garage door, adjust, road test. ;)
    That's all I can think of right off.
  13. ContraHusky Husqvarna
    Dropped my oil yesterday at 152 miles. I was rather surprised at how dirty it was - dark and muddy. Lots of suspended solids. Magnet on drain plug was thick with metallic dust.
    Will do the filter and screens at 600 miles. Then I can FINALLY twist the throttle and see what this beast can really do!
  14. CJBROWN Husqvarna
    Orange County, CA
    '15 R1200GS
    Yeah, I saw the same thing at 220. Was glad I changed it. And it's easy to do!
    I figure I can get to 1000 miles now, do the valve check, filters including the inside screen, and switch to full synthetic.
  15. Carsondriver Husqvarna
    thanks Guys.. Lots of great advice. I will spend Sunday Morning going over everything!..
