Kayaba Fork Rebound Needle Removal
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by RailwayRog, Feb 11, 2012.
  1. RailwayRog Husqvarna
    Got a 2011 Husky te310 that I'm changing the fork oil in. While I have the forks apart I wanted to grease the rebound needles (to prevent seizing up). I have done this on my KTM, the needle popped right out by sticking a thin straight object thru the mid-valve.
    I tried this on my Kayaba and the needle doesn't want to pop out. I did not want to put undue force on it, so my question is, does this needle pop out or do a I need to break down the mid-valve to get at it which I'm not willing to do. And yes when apply pressure to the rebound rod I can feel the spring tension so it is not seized up.
    I can't find a lot of information on these forks on the internet so I'm kind of flying in the dark.
  2. JasonfromMN Husqvarna
    MN
    None right now :(
    2013 Yamaha FZ6R
    Can you provide a pic?
  3. RailwayRog Husqvarna
    The needle valve is down deep in the rod on the other side of the mid-valve. Someone answered it on another forum and says I don't have to worry about it seizing up and the needle doesn't pop out, so I would have to disassemble the rod which I'm not going to do.
  4. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
    Yeah, don't wory about it, it's not like a WP fork. But, if you take the rebound / MV holder off the end of the rod you can get it out.
  5. RailwayRog Husqvarna
    I tried twisting off the MV holder and later discover somewhere on the internet you need to heat it in order to remove the holder. No way I'm I doing that.
    So thanx for all the replies out there, this makes me feel a lot more confident about performing my own maintenance and understanding how things work.
  6. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    Heating it isn't a big deal, it just need warmed up a little. Not skinning the shaft up is the part to worry about.
  7. RailwayRog Husqvarna
    Any other Kayaba fork maintenance tips you can pass while I have most everything apart?
    As it turns out I'll be replacing the stock springs with something heavier. Haven't figured out the rate yet.
    Thanx again Motorhead
  8. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    No, they're pretty straight forward. Warming the tubes up before you drive the bushing and seals in helps a lot, but that works on all of them.
