250-500cc keihin pj 38mm
Discussion in '2 Stroke' started by hellbergarn, Jan 1, 2015.
  1. hellbergarn Husqvarna
    SWEDEN
    Husqvarna tc 250 2014 husqy te 250
    beta 350rr
    hi i found a keihin pj 38mm carb in my garage i think it comes from honda cr 250
    is it worth to try to get it on and swap out the mikuni? i have a hva wr 250 2011
    and what should I use for lowspeed highspeed
    nozzles?
    and also do anywon have the org shimstacks to the kayaba forks?
    thx Daniel
  2. letitsnow Husqvarna
    mn
    FC250
    CBR600F4
    Unless the Keihin is a PWK, I would not bother.
  3. hellbergarn Husqvarna
    SWEDEN
    beta 350rr
    are the pj carb so bad?
  4. letitsnow Husqvarna
    mn
    FC250
    CBR600F4
    They aren't too bad. I used to use them on my late 80's TRX250R's. The newer style TMX is better than the PJ, and the PWK is better yet.
  5. R-J van Hulst Husqvarna
    Cambodia
    Honda CB 400 Vtec 3
    How much would you charge for an hour of work?
    A lectron out of the box (which is darn close to perfect tuned when you indicate the bike type of riding and location while ordering) will set you back less then $400
    its just a mater of time question and how valuable your time is to make a decision
    Robert-Jan
    justintendo likes this.
  6. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    i can live with other carbs but if im shelling out money it will be lectron. the custom fitting they provide makes it even easier
  7. Joedints Husqvarna
    Medford, New Jersey
    11 WR300 13 WR125 81 WR430 82 CR250
    Kawasaki ZR7-S
    A good thing is alot of the parts including needles and jets will fit a PWK from your PJ... Keep an eye out, I brought one for $25 at a swap meet.
