125-200cc keihin pwm 38mm
Discussion in '2 Stroke' started by andre berntsen, Aug 21, 2013.
  1. andre berntsen Husqvarna
    WR 125
    aprilia rs 125, ktm excf 250-350
    so i'm no mechanic, but have the chance tochange out my delortor 28 mm carb for a keihin pwm 38mm will this fit and is it a good choice?
  2. oregonsage 4st Clerk
    Dry Washington
    FX450
    Yamaha DT400 x 2, BMW G310R
    Could you tell us more about your bike that you would install it on? Model, year, modifications?
  3. andre berntsen Husqvarna
    WR 125
    Oh yeah sorry, it's a 2004 husky sms 125cc the only mods are FmF exhaust and carbon reeds i think, i have to change the carb either way as the one i have has a big crack so gas is pouring out!
  4. oregonsage 4st Clerk
    Dry Washington
    FX450
    From what I see, a PWM is a race only carb, the PWK is more popular and better for tuning all around. You will find lots of PWK setup advice around here......38 sounds a bit big for a true 125....Also check the that it will fit as the PWMs are shorter.
    That said, if it fell into your lap then its probably better than a leaky delorto....
  5. andre berntsen Husqvarna
    WR 125
    Well i'm getting it for about 180 dollars, which is like a third of what it normally costs, the wr is stock with 38 mm so i don't see the problem there also changing to the 144 in a while (when i get some money), do you think the lenght is an issue? i have to drive 3-4 hours to get it so it'll be kinda a bummer if it doesn't fit.
    what's the difference between a race and a normal carb?
    really sorry for this trouble and my bad english, but you've been real helpful and i'm thankfull for that!
  6. oregonsage 4st Clerk
    Dry Washington
    FX450
    That is about as much help as I can provide. I would get a length measurement from the seller and make sure it will fit in your bike. Motosportz jmetteer and wallybean are guys who you might want to PM as they know a lot about what works on the 2 strokes.
    Where are you located? $180 is a lot of money US for a used carb.
  7. oregonsage 4st Clerk
    Dry Washington
    FX450
    Also, to PM here go to Inbox at the top, open it and select Start a New Conversation....then you can enter those names to send them all a message.
