Kenda Tube Stop Nuts
Discussion in 'General (Main)' started by pcross71, Sep 26, 2010.
  1. pcross71 Husqvarna
    New York
    Just installed a new Kenda Tuff Tube on my rear wheel (first time, boy those videos make it look easy) and the tube came with two stop nuts on the valve stem. It looked like the first one had to go inside the rim to hold a concave washer against the tube - so did one nut inside and one outside. But I wonder if both were supposed to go outside locked against one another (i resisted this as it was hard enough to get the valve stem through the hole without worrying about the washer dropping into the rim). Anyone know? And if I did incorrectly, will the nut inside the rim (between the rim tape and the tube) create a problem (bad enough to pull it all again...)??
    Thanks!
    Peter
  2. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    I have seen tubes run with one nut inside the rim and one out, and I have also seen rims run with none on the inside and one on the outside. I've even seen them run without any locknuts on them anywhere. I usually run them with one on the outside.:excuseme:
  3. Up-tite Husqvarna
    Always check the tightness of the one next to the tube. The other ones sole purpose is to keep the valve stem from pulling back in and loosing it inside when putting the tire on. After tire is aired up DO NOT tighten it up. It should go up against the valve cap.
    Many think it is susposto be tightened.
    Reason not to is so you can see if the valve stem is starting to lean this is caused by the tire slipping on the rim, with the valve stem tight it will tear it off the tube.
    If it starts to lean then just have to deflate the tire break the bead loose put something between spokes and swing arm pull tire back so stem is straight again and reinflate it.
    Later George
  4. pcross71 Husqvarna
    New York
    Thank you both for the help - so i guess the take-away is (a) the second nut is fine on the inside and (b) the outside nut goes against the cap, not the rim - THANKS! George - i take it you're able to break the bead with the wheel mounted? Or do you remove, break, and reinstall to pull the tire around the rim? If on the bike, how?? I had to push awful hard on the bead to break.
    Thanks.
    Peter
  5. Up-tite Husqvarna
    Just have to do what ever it takes, sometimes tire iron will do it, large water pump pliers,dynomite or c4 some get really stuck.
    Later George
  6. Dirtdame Administrator
    Rock Springs Wy
    17 Beta Xtrainer
    You could use a C-clamp to break the bead. I have, on occasion.
  7. Logroller Husqvarna
    I have a variety of responses on forums, but I'm trying to see what Kenda intended.
    However, per these shops they are consistently stating the same; washer and nut against tube, one washer outside of rim.
    http://www.rockymountainatvmc.com/
    parkeryamaha.com
