Kickstand too far forward ? Simple Solution
Discussion in '4 Stroke' started by Kevin_TE250, Oct 22, 2008.
  1. Kevin_TE250 Husqvarna
    Boise Idaho
    Thought about it and came up with this as opposed to welding a stop down there.
    Get a simple hose clamp:
    put it on the base of the kickstand above the spring.. it will be a little loose but will position nicely up or down... Use some locktite on the screw:
    Now it won't go all the way forward !
    Happy bike !
  2. Coffee CH Owner
    That is an ingenious idea, and I can use it.
    Thanks!
  3. Kevin_TE250 Husqvarna
    Boise Idaho
    In retrospect
    I'm thinking a heavier hose clamp would probably hold up better.. I just happened to have that one around and used it....
