Hi, is the kickstand you carry a possible fit for the 2010 TC 250? Any idea on the modifications needed to make it fit? thanks, JS
will not work. Do you have a frame tab you can mount to? The stock one on my 2010 TXC and 09 WR125 is a very good unit.
Hi, that is what I am thinking. I am going to weld on a tab and use the stock WR/TXC kickstand. I may try mounting it so it tucks up a bit higher though. Thanks! JS
