knocking at front end.
Discussion in 'TR650' started by bikehunter, Sep 21, 2013.
  1. bikehunter Husqvarna
    Hampshire
    Strada 650
    Harley, bmw, moto guzzi
    Pushed the bike up the drive and applied the front brake and heard a knock, had a feeling it may be the headstock bearings but maybe forks, anyone else had this?
  2. RuggedExposure Now with more rugged!
    BFE
    Terra 650
    '08 Meanstreak 1600, '95 DR350
    Yes.
    Never figured out what it was, but if I brake really hard on pavement I can get it to make that noise. Almost sounds like something is breaking or tweaking the forks.
  3. AUS_TR650 Husqvarna
    Australia
    2008 KLX250S
    Probably the clutch cable rubbing...
  4. James Rideout Husqvarna
    Nova Scotia, Canada
    Rm250, DR650
    I hear the same thing, when I push it out of my shed on my lawn. I've pushed that thing all over my dam yard with my ear near every front end part to figure out where it is coming from. My guess is they used cheap low tolerance bearings and race's in the triple tree. If I find it getting worse ill get them replaced at a bearing shop with some higher tolerance fit bearings.
    Ive actually been looking in the Terra service manual for the torque on the triple tree nut. The witness mark on the nut hasent moved since factory but I was gona break the torque and try it again, see if that helps. Havent found the torque spec's yet though.
  5. bikehunter Husqvarna
    Hampshire
    Strada 650
    I think the way to check is to jack up the front and push and pull the legs, not sure about the clutch cable but will have a look in the morning.
  6. hasenpfeffer Husqvarna
    CO
    I think it is this?
  7. HB Strada Husqvarna
    San Juan Capistrano
    2013 TR650 Strada
    Buell XB9SX/Specialized Exp Evo
    Same issue here, BMW techs couldn't figure it out. There is a knock when the suspension changes direction (up and down).
  8. MotoFan Husqvarna
    Portland, OR
    2014 TR650 Terra
    Kawasaki Concours 14, Yamaha WR250F
    Does the TR650 have a floating rotor? I've noticed this knock or click when hitting the brakes on other bikes I own. Usually when you push it backwards and hit the brakes.
    mag00 likes this.
  9. bikehunter Husqvarna
    Hampshire
    Strada 650
    Lifted up the bike last weekend and found no play in the forks so its either the brake as MotoFan says or the forks at full extension!
  10. mag00 Husqvarna
    Tucson
    Terra, Strada
    XR250 R1100RS CH50
    Replicate the fork dive without using the brakes. You can run it into a block or wall at slow speed, maybe with a friend pushing and balancing. My first thought was brakes. I can't imagine bottoming out or fully extending the forks just pushing it around and hitting the brake.
  11. bikehunter Husqvarna
    Hampshire
    Strada 650
    Well if you run it up a small curb without using the brakes, there is a small knock and you feel it through the bars and that's without using the brakes.
    To me if the forks are at their highest point ie fully extended with no compression, there seems to be play that may contribute to the knock as it does it after the brakes are released and the forks come back to rest
  12. Highfive Husqvarna
    Husaberg FE390, BMW F800GS
    I've noticed the knock also. It feels inside the forks, to me. I think it's a topping out knock....possibly. My steering bearings are fine & proper. There is no excess play there. I'll inspect the forks carefully some day whenever I take them apart for servicing. Until then, I'm not losing any sleep over it. Everything seems to be functioning correctly. I've inspected the important areas carefully at least three times.
    HF
    bikehunter and Scutler like this.
  13. wayfarer Husqvarna
    Ducati M900
    I was thinking it was the fork valves. While seemingly loud it does correlate to when the fork changes from compression to rebounding.
  14. DerBrizon Husqvarna
    2005 Suzuki SV650S
    I didn't start hearing/noticing this until this afternoon when I blew my fork seals. It has me worried.
    Also: What is up with the cost of a set of fork oil/dust seals?! I just paid 150 bucks and it'll be two weeks for them to get here.
  15. Nordland Husqvarna
    North of Germany
    TR 650 Terra
    Very interesting...
    I also heard this type of knocking noise coming from the front of my Terra, kind of cklicking or ratteling and i was afraid of something broken.
    Had several phone calls to the dealer i bought the bike from. He tested some brand new Terras and Stradas in his show room. All this bikes made this clicking/knocking noise when compressing/rebounding the fork.
    So i made call to the german importer of husqvarna. He also tested his brand new Terras... after testing six bikes his result was that all of them make this special noise.
    A few weeks after this call i made an appointmend with a husky dealer specialised on shock equipment, because i wanted to know what the cause of this noise is.
    He was testing an hearing more than one hour at my Terra.
    His result: When compressing/rebounding the fork the springs are beating minimal to the inner fork tube.
    His phone call to the importeur gave the same result, nearly every Terra/Strade is making this special noise.
    All of them told me that this is nothing to worry about... so i will trust in this statement.
    Until now everything works fine, no leaks, no loose... seems to be only an unpleasant thing.
  16. Ogre_fl Husqvarna
    Cook Bayou, FL
    Terra 650
    Tiger 1050
    Norland,
    Thanks for digging so deep on this.
    It is a relief to know that nothing internal is loose or broken.
    Like Highfive, I have gone all over my front end and confirmed that nothing external was loose or broken, but I was never sure on the internals.
    That said, it still sounds and feels like crap and detracts from an otherwise solid feeling bike.
    I wonder if there is a way to shim the springs to stop it from beating/banging against the tube.
    FER QUILES likes this.
  17. Stefan NZ Husqvarna
    Christchurch New Zealand
    TR 650 TERRA 701E
    I have the same issue with my TERRA. It's only coming from one fork. I definitely intend to get this sorted. The one that doesn't knock feels smooth up and down whilst the knocking one (apart from knocking) feels sticky.
    I will keep you posted on how/if I get it sorted...
    nev.. likes this.
  18. kiwiape Husqvarna
    650 Terra
    Aprilia DD750
    mine does the same when the forks change direction....I am pleased we all have the same fault and it has been nothing more than any annoying knock.
    Moff69 likes this.
  19. Slowflyer Husqvarna
    TR 650 Terra
    BMW R1150R Rockster
    My Terra has the problem. The dealer in conjunction with the distributor is reasonably keen to have it fixed noting that it appears only to be an irritant and not a material problem.
  20. RacerAV Husqvarna
    '14 TR650 Terra
    '13 Honda Ruckus, many others before
    If I'm rolling backward and hit the front break, or just plain ol yank up on the bars, I hear a small clunk. Everytime. 250 miles on the bike. It sounds like a loose bearing, or mount somewhere, not sure...
