125-200cc Knocking sound when slowing down
Discussion in '2 Stroke' started by Mr_X, Nov 1, 2010.
  1. Mr_X Husqvarna
    Singapore
    My wr125 has a new piston and ring and the cylinder has been polished.
    When i slow down the bike by shifting down gear, knocking sounds came from the engine, this makes engine braking not smooth as usual. Should i change cylinder? Or get a slightly bigger piston in the market or ...
    Thanks for viewing
  2. ray_ray Mini-Sponsor
    The Philippines
    You said you have a new piston and ring for the bike? Where did this piston come from and was it not the right size?
  3. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    Maybe you should check the clearance between the piston and the cylinder wall. you will need to know the manufacturer's specifications. If you don't know how to do this properly, have somebody who does know how do it for you. I'll bet that there probably isn't more than about two thousandths clearance required for such a small bore.
  4. Mr_X Husqvarna
    Singapore
    Thanks, i'll ask my mechanic what has been done to my bike soon.
  5. pvduke Husqvarna
    ... on the gas...
    tripple-hondo hoosk...
    is this a mechanical knock or a ping/spark knock?
    check your chain for excess play, it can cause a slapping on the buffers/block.
    maybe your bike is running on- too lean on the slow circuit. reverify your pilot jet, maybe go up one and re-verify starting with the air screw 1.5 turns out.
    the symptoms are kinda vauge so i'm reaching here...sorry. hard to diagnose a random noise over the 'puter.
    best of luck sir and hope it aint serious.
