125-200cc kokusan flywheels: difference between wr 250 and wr360.
Discussion in '2 Stroke' started by CiCoWR360, Mar 1, 2016.
  1. CiCoWR360 Husqvarna
    wr 360
    They have different codes. I would like to know the difference between the two in question . if I mounted a flywheel of the 250 on the 360 , I would have to time differences ignition ? Thanks.
    Petar likes this.
  2. uranys Husqvarna
    Pittsburgh, Pa
    96 xr600r
    At one point I tried using a wr125 flywheel on my 360 and it didn't run, so I'd say no.
  3. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    Ive had a 99 250 and own a 02 360, cdi's swap over as far as im aware the shafts and taper are the same the stators the same just the cdi had a different map...
    I will say i never swaped just the flywheel but im sure its a crossover part.
  4. Busted RS Husqvarna
    Perth, Western Australia
    2011 TE630, WR300 '09
    DT360A's
    I have both and the key way is located slightly differently from one to the other, very approximately 5 degrees ish different if memory serves me correctly, and the stators appear identical. Not at home or I would go and look. If you look up the settings for each bike, that might give you a clue.
    Power on regardless
    juicypips likes this.
