kph to mph 09 speedometer
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by Riksha, May 11, 2009.
  1. Riksha Husqvarna
    So Cal
    I have tried afew times and go out and mess with it every now and then to see if I'm doing something different. Read & reread the manual. I did a search..
    What is the routine to get the speedometer to read mph instead of kph
    on a 09 te450?
    Scroll to the right window on the speedometer, pull the clutch in, hold the button down, use my forearm to hit the starter button... the thing doesn't go from kp/h to mph :banghead: :excuseme: :banghead: WTH?!?
  2. gearstace Husqvarna
    Idaho
    Good luck, Riksha. I went through the same thing with my 09’ and was getting so frustrated not having 3 hands to do what the manual stated. I ended up holding the button down on the trip computer and cycling the key and somehow got it to work. I wish I knew exactly what I did but at that point I was so pissed off I was just pulling levers and pushing buttons and swearing a lot. All I remember is that you do not need to start the engine (I think). I will try to duplicate and post if I luck out and get it right. Sorry not much help but I feel your pain.
  3. Vansmack Husqvarna
    Los Angeles
    Have the display set to speed and ODO. Turn the key off. Hold down the display button while turning the key on. Keep the button held down until KPH shows up on the display, then let go of the button. After a few seconds it will alternate between KPH and MPH for a few seconds each, press the button when it is on MPH.
    Yeah, did that whole hand, foot, and knee thing too. When they say "Start", they simply mean turn the key to On.
    Chris
  4. rajobigguy Administrator
    So.Cal.
    That's the key right there. If you start the engine the computer locks it self into what ever mode it is in. Oh yeah it's helpful to have a pet octopus, a well trained one, to help with the initial set-up.
  5. Doormandan Husqvarna
    So Cal
    Found this on TT http://www.thumpertalk.com/forum/showthread.php?t=330436 Has a lot of info on this subject. Perhaps we should keep it in a sticky?:cheers:
  6. Riksha Husqvarna
    So Cal
    Wow...
    Man I had my wife out there handling the start button, I had the clutch pulled in, finger on the speedometer, looking at my wife tellin her the italians were having a good laugh right now.... :lol:
    Thanks all. :thumbsup: :notworthy:
    Walked out there with the right info and it took ten seconds...Dang :applause:
  7. rajobigguy Administrator
    So.Cal.
    This is from the TE 610 service manual (2006) but you may find much of it applies to other models. It's a better English translation than most.
    ELECTRIC SYSTEM
    DIGITAL INSTRUMENT, WARNING LIGHTS
    1- GREEN warning light Lights
    2- GREEN warning light Neutral
    3- B ATTERY CHARGE warning light (the warning light comes on, contemporarily with the vertical LED indicator 10, when the
    engine is stopped and the ignition key is on
    IGNITION position)
    4- 1st ENGINE OIL REPLACEMENT warning light (the warning light comes on after 1000 Km/620mi. approx.; it is necessary to
    carry out the Service Coupon A)
    5- MAINTEN ANCE warning light (the warning light comes on after 5000 Km/3100mi. approx.; it is necessary to carry out the
    Service Coupon B)
    6- MAX ENGINE r.p.m. warning light (the warning light comes on after that the vertical and horizontal LED indicators have
    completed their stroke: 8250 r.p.m. approx.)
    7- GREEN warning light Blinkers
    8- BLUE warning light High beam
    9- AMBRE warning light Fuel reserve (3l; 2.6 Imp. Qt.; 3.2 U.S. Qt.)
    10a: Vertical LED indicator BATTERY CHARGE (the indicator is on when the ignition key is on IGNITION position and the engine
    is stopped; if the battery charge is below the middle height of the indicator, charge the battery. When the engine starts, the
    indicator stops the battery check and starts the tachometer running)
    10b: Horizontal and Vertical LCD indicators TACHOMETER (both indicators are on when engine starts: the end of the indicators
    stroke shows 8250 r.p.m.)
    23
    ELECTRIC SYSTEM
    Instrument settings
    This operation allows you to set the parameters of the instrument for use on
    motorcycles with different characteristics (SM-TE). To begin the editing process
    proceed as follows:
    1 - With ignition off press and hold the MODE button
    2 - With the MODE button still pressed, turn the ignition on. After around 7
    seconds WS will appear in the lower right corner of the display. Release the
    MODE button now to skip to step 8 or keep it pressed to continue to step 3
    Setting w heel diameter
    3 - Keeping the MODE button pressed, press the passing light switch 5 times
    4 - Release the MODE button and the "0001" (for SM model) code will appear,
    fig. 3
    5 - Press and release the MODE button and the "0002" (for the TE
    model) code and subsequently the writing "cu" shown in fig. 4;
    6 - After selecting code (0001 for SM and 0002 for TE), press and hold the
    MODE button until WS re-appears. Release the MODE button.
    7 - Press and release the MODE button now to display the first of five noneditable
    screens as follows:
    "Ln" = development wheel (fig 5)
    "di" = diameter rotates (fig 6)
    "SPEED" = n° impulseturn wheel (fig 7)
    "rpm" = n° impulse/turn engine (fig 8)
    "max" = out limit turns (fig 9)
    Setting units (Kilometers / Miles)
    8 - Press and release the MODE button to show the Km/h - Mph screen
    (fig. 10). Press and hold MODE button up to the appearance of the horizontal
    bars (not shown) then release. A unit of measure will be flashing which is the
    active units. Press and release the MODE button to change from Kmh to Mph
    & vise-versa. Press and hold the MODE button until WS re-appears to accept
    your selection
    Setting oil change warning interval
    9 - Press and release the MODE button until you see the oil change symbol
    (fig. 11). Press and hold MODE button until the horizontal bars appear (not
    shown), then release. You are presented with NO, clear? . Press and release
    the MODE button to see YES, clear . Press and hold the MODE button until
    the screen blanks. Release the mode button to see "0000" or the value previously
    inserted with the first number flashing. (initial setting is 13h for the first
    oil change) Shortly pressing MODE the number advances one, allowing it to
    flash for 2 seconds the second left number will begin to flash. Set to the desired
    interval. (See the Maintenance section for recommended intervals)
    Setting the maintenance w arning interval
    10 - Press and release the MODE button until you see the maintenance symbol
    (fig. 12) Press and hold MODE button until the horizontal bars appear
    (not shown), then release. Press and release the MODE button to select distance
    or hours as the interval. (fig. 13 distance will be Km/h or mph) Press
    and hold the mode button until WS briefly flashes in the lower right corner of
    the display then release. Follow the same procedure as outlined in step 9. to
    set the interval.
    To exit setup cycle through the screens until END appears. Press and hold
    the Mode button until the horizontal bars are displayed. The instrument will
    reboot into standard mode. You may also turn off the ignition to exit setup.
    24
    ELECTRIC SYSTEM
    Adding / Removing Screens
    This operation allows you to add and remove different screens (functions) to the unit. The computer contains 9 screens in all. The
    screens may be shown with the bar graph acting as a tachometer or a battery meter. (you must show one or the other on all
    screens)
    To begin turn on the ignition and allow the computer to complete it s self diagnostic. Press and hold the MODE button until WS
    appears in the lower right corner of the display. Refer to the table for the effect on each screen.
    Switch RPM / Battery Meter Graph
    While displaying the RPM screen, hold the MODE button until WS appears. The RPM screen will be removed and the battery
    meter will be displayed on all screens.(fig.11) To restore the RPM graph, restore all screens and cycle the screens until the RPM
    screen is displayed
    Screen Effect
    Hold till WS Hold till horizontal bars (see fig.9)
    Odometer (fig.1) * Restores all other screens N/A
    Trip Odometer (fig.2) Remove screen N/A
    Average speed (fig.3) Remove screen N/A
    Maximum speed (fig.4) Remove screen N/A
    RPM (fig.5) Remove screen / switch to battery
    meter
    Adjust engine redline warning
    Clock (fig.6) Remove screen N/A
    Clock (minutes:second) (fig.7) Remove screen N/A
    Lap 1 (fig.8) Remove screen Reset timer
    Lap 2 (fig.10) Remove screen Reset timer
    * If all screens are displayed this removes all screens except Odometer.
    25
  8. Coffee CH Owner
    This thread needs some diagrams of the instrument cluster.
    It is a bit hard to follow for dubm people like me that need all the help the can get.
  9. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
    Wow :eek:
  10. rajobigguy Administrator
    So.Cal.
    OK but that may take some time because dumb people like me have to figure out how to take full pages with images, one at a time out of a pdf file and post directly to a website without going to a clipboard and word document.:D
  11. Coffee CH Owner
    And this morning my laptop died and I'm limping along on a PC with an 8GB drive which does not have the 610 workshop manual nor can I install an extremely handy program called 'screen grab' which is a plugin for firefox. Only takes a small bit of space but we are down to the last 200KB on the hard disk.
    While you are downloading things find Iranview - super handy photo editing program.
    We may need to work on this later.
  12. rajobigguy Administrator
    So.Cal.
    No, I may not know what I'm doing but I'm pretty creative about finding the hard way there, give me a few minutes.
  13. rajobigguy Administrator
    So.Cal.
    Ok you're right I'm going to have to do this later. I figured out how to get full page print with images on excel and I'm pretty sure if I send them to my E-Mail that I will be able to copy and paste into the Cafe posting window but I have to send them to me via outlook which I don't use and the wife isn't here to tell me what the pass word for out look is.:excuseme:
    Can't say I didn't try.:lol:
  14. Coffee CH Owner
    I just got back to this.
    Let's wait till my computer is fixed - Monday?
  15. raisrx251 Husqvarna
    Virginia
    I have a question for anyone with a '08 TE. My clock is showing up in Military time but my odometer reads in MPH. Does anyone know how to change the clock? When I reach clock I can hold down mode and get to set it but I do not see how to get it over to normal time. Thanks.
  16. Vansmack Husqvarna
    Los Angeles
    OOOhhhhh, I wouldn't mind that problem. Sorry, I've seen no mention of that in the 09 manual.
    Update; Now that I am actually looking at the manual, it ONLY shows that it is 24 hour clock.
    From the manual...
    "CLOCK: clock - Reading from 0:00 to 23:59:59;"
  17. kpie Husqvarna
    Utah
    Ha.....! I was doing the same thing. Had my wife turning the key, starting the bike...... damn italians.
