Kreft suspension
Discussion in '4st' started by Chums, Mar 28, 2015.
  1. Chums Husqvarna
    I'd like to discontinue my account
    Seems the 2 stroke section is the place for 4cs talk so here it goes.
    I originally had Halls spring my FE350 for my weight, at first it was OK but the front was just not sticking like the old red and blacks I'd had, after 15hrs seals leaked got fixed, after 20hrs suspension was unridable soft. Next went to a local husaberg/husky suspension guy new springs stiffer valving, way to stiff, did it again still no good, sent to zip Ty much much better than stock but as I road it got harsh didn't feel balanced, FINALLY bit the bullet and sent to Kreft!
    So this whole kreft experience was top notch, communication was great, Adam talks to you personally and makes notes and keeps it in a file so no need explaining everything over and over. I went whole hog with Huck valves and the whole deal! Cost me extra to replace removed parts and patch hole in seal caps, had to buy springs for forks as well. In total with shipping and repairs I'm into it for $1700, and yes it hurts to even type that dollar amount but I had spent $1600 screwing around with all the stuff before that, yes hindsight is 20/20...
    The review, my bike handles completely different COMPLETELY! It is the best suspension I have ever had or ever ridden period. I had two buddies ride it and both got off smiling and amazed that it floats over everything, rocks, trails junk, small logs you can't even feel but you still feel connected and confident! Corners, this baby carves now super balanced just lay over and apply gas!
    I still wince when I come in hot to ruts and whoops and I still wait to let off because the front is going to wash out but it just doesnt! Its really amazing. I fought arm pump last year and it diminished by at least half or more today. I actually had a good time today for the first time since I bought this bike and can't wait to ride it again tomorrow! I guess what I'm saying is my bike is fixed!
  2. BDHANSON Husqvarna
    Southwest Washington
    2014 TC250
    Nothing beats having suspension that works the way you want.
    Big Timmy and Chums like this.
  3. Big Timmy Husqvarna
    (South Eastern) AZ.
    Chums, Thanks so much for your honest information on the Forks set up. I'll be sending mine out to Kreft also to get it done right the first time.
    I have a brand new 15 FE 501 being shipped as we speak on its way from Bills in Oregon down to me here in Arizona.
    I only got quotes from 2 different places, him and the KTM/ Husky dealer closest to where I'm at in S.E. AZ. and I went with "Bills MC Plus" I didn't even bother to shop around and listen to how these dealerships are going to add this and that to run the price up another $1600.00 to $1800.00 onto the base price.
    It's bad enough already when I have about $3,500 in goodies sitting on the living room floor to add to it when it gets here already. Mostly protective pieces in nature, such as slave cylinder guard with the built in case saver ,case guards, linkage protection, swing arm side protectors, side frame protection, different brake pedal tip and a longer shifter for my size 12, a better skid plate. New S/S oil filter and a few "twin air" spare air filter, front and rear disc rotor guards. A Zipty fuel filter and XF2 coolant. Still don't know if I mad it on the list for a GT 216AA tire or not. Paid for one but don't know how long the list was? 135 tires showed up as of last week but probably of different sizes and the list of people waiting was 68+ customers deep but who knows. Some of those may have stocked up on several apiece. got my other stuff from ZT in like a day. They ship fast.
    I bought the factory complete kicker assembly to install for back up, Sicass map switch and complete lighting kit with switches and harness but without the signals, Its all supposed to plug directly into the factory harness. Even has a puny horn. So I can get it tagged and plates easily. A full FMF Megabomb system, the list goes on and on.
    "Bills" swapped out the fork springs for my weight free of charge as he had a customer that wanted to try my stock rate springs so I couldn't pass that up. They mapped the ECU with the Euro map. I was the first one he ever had done that to for the FE501 as he says. Got the proper rear spring with several other bits and pieces from "Slavens" with an Xtrig Preload adjuster so I can lose the spanner wrench out of my fanny pack.
    I've read and researched these 4CS issue threads very intensely. I have also learned a thing or two doing so and have familiarized myself to some extent with the WP suspension set up on my G450X BMW 4860s and 5018 Trax shock although totally different internally. I don't want to waste money doing this 2 or 3 times. I got a good pelican rifle case already to ship them off to Kreft..
    I'll take the FE501 out for the first few rides just to put a few hours on them to loosen them up after everything else gets bolted on and after the first oil change and a few more hours it'll be time. So when I go over the bike after the first look over and service. They are coming off to get done right away after that, I'll wait until after the first few rides as its starting to get hot here already. I'll have to ride the BMW I guess while they are off getting redone. I know it's dialed and works, I'm keeping it for a loaner bike so I can bring someone out to ride with us when we go. I know its sorted and stone reliable.
    I can't wait for the new Husky to show up though.
    What is his average turnaround time and total cost to do the full on job with the Huck valves if he starts fresh and doesn't have to do rework from other shops previous modifications??
    You can PM me if you would like.
    Thanks Tim
    Norman Foley, Chums and Bomber1b like this.
  4. Chums Husqvarna
    Well it got broken in today at the first Enduro of the year in our district. IMG_20150329_135924771.jpg IMG_20150329_135910495_HDR.jpg IMG_20150329_135857944.jpg
    KXcam22, ray_ray, robertaccio and 2 others like this.
  5. Norman Foley Husqvarna
    So how was the baptism under fire?
    Chums and Big Timmy like this.
  6. Chums Husqvarna
    Haha, great considering as the day went on the ground got super slimey. It was tough but the first two tests were awesome! I normally run mid pack A but today my AA buddy , who finished 3rd overall, and I mixed it up for the first 2 tests until his running and working out took over and my lack of all that took over lol.
    It just eats whoops and logs, I'm way less tired, no jarring, no harshness anywhere. Still feel very good about it, went one click stiffer on fork comp just because of the chance of mud.
  7. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
    mud in Iowa ?? HOW ODD:lol:
    Chums likes this.
  8. Chums Husqvarna
    Yeah ya get used to the standing two wheel drift balance act with the spring rains around here. This was in Illinois but hey they both start with an "I" and are both muddy lol. I could have certainly picked a better tire set up, had my "do it all" set up m59 front sedona 880 rear @1psi, would have been nicer to do a mx32 front and an irc m5b rear at this place anyway.
    Big Timmy likes this.
  9. Motosportz CH Sponsor
    Good stuff. Just found out the other day I can get Zoke 48mm extreme forks for $1600 for a complete set!!! So if someone wanted they could sell the 4cs and put the zokes on and probably loose no money.
    HuskyMax, Tinken, robertaccio and 4 others like this.
  10. reveille Husqvarna
    Northern Illinois
    2014 FE501
    2015 300 XC W
    I thought about selling the 4cs and buying another set of forks for around the price you mentioned but, if I did, the new forks would still need to be adjusted for spring rate and valving so adding that cost put it well over 2k.
  11. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    ZipTy 48mm Shivers come fully sprung and valved, and they don't have to be red. Same forks Dalton Shirey and Ricky Brabec/Robby Bell run. The best way is just to toss Shiver cartridges into your fork chambers. This gives you the best forks for the least investment.
    Image above is Dalton's 4CS WP tubes with Shiver cartridges.
    http://www.cyclenews.com/708/32729/Racing-Article/Robby-Bell-Wins-Havasu-WORCS.aspx
    robertaccio likes this.
  12. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
    its about time you commented on this. (;)) I am still considering this......tax refund on the way!!!(for once in my life)
    But this should be a thread of its own, not under this Kreft thread.
    454x, Chums and Tinken like this.
  13. Chums Husqvarna
    Agreed the shiver forks really need its own thread as it is not related to the title of this one. The intent was to share info and experience with Kreft suspension so people can make informed choices.
  14. be350ka Husqvarna
    2015 TE 250
    Did you expect anything different?
    Big Timmy, Lincolnlock and Chums like this.
  15. Motosportz CH Sponsor
    Tinken and Chums like this.
  16. robertaccio Husqvarna
    San Diego, Ca
    focus my brothers, its better to keep on title track so when we search for info we have direct access to the stuff we are looking for. You guys know that.
    Kam1, ray_ray, 454x and 6 others like this.
  17. Aaron platt Husqvarna
    Central Oregon
    17 TX300, 17 FE450
    16 Beta EVO 300
    How much would this cost? Also, can I buy a set of those graphics for my Ktm shrouded 300?
  18. Chums Husqvarna
    Lol!
    There's a Zip Ty suspension thread down by the Classified section. Just saying that might be a place to check.
    robertaccio and Big Timmy like this.
  19. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    PM me so we don't threaten Chum's discussion.
  20. Aaron platt Husqvarna
    Central Oregon
    17 TX300, 17 FE450
    16 Beta EVO 300
    If we're gonna get all uptight about what's said where, doesn't this whole thread belong in the 4t section since it pertains to your 350?? There is a little too much whining going on here.
    LandofMotards and Big Timmy like this.
