ktm wrap around fork gaurds on husky's
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by dan s, Feb 8, 2013.
  1. dan s Husqvarna
    united states N.J
    2013 wr 250 A-Class
    I thought this was interesting KTM wrap around fork guards fit on husky's. IMG951257.png IMG951257.png
    Phoenix likes this.
  2. Enduro450 Husqvarna
    New Zealand
    2008 TXC450, 2013 TXC310R
    Yep, been running white ones on my 310, they look pretty frickin cool!
    Use the GASGAS ones tho, they unclip at the back for easy removal
    dan s likes this.
  3. Kyle Tarry Husqvarna
    Portland, OR
    2012 WR 300, 2006 TE 610
    Ducati Monster S2R 800
    What model KTM did you get the ones on your 310 from? I think 310s have the same forks as my WR, so they ought to fit mine too.
    How do the KTM pieces install? Do you need to drop the fork out of the triples to get them on?
    Motoplasticsus has a set of black guards for 2008 KTM EXCs for $30: http://mysite.verizon.net/motoplastics/exc08.html
    I already have one broken one on my WR, maybe I should try those...
  4. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    If you use gas gas items you can get them in red blue white, friend of mine went red while I went white and I prefer his to look at
    The ones that clip together can rub the forks a lot more than the full moulded items as they dont stay perfecly round
  5. Enduro450 Husqvarna
    New Zealand
    Pretty much all KTM and husky fork guards have the same bolt pattern im pretty sure, the later model KTMs (08 onwards?) have the wrap around guards.
    They fit on my 06 te450 and the 08 txc450 too.
    I got mine from polisport, very strong once bolted on and seem to rub a lot less on the forks than the stock ones i think and they work perfectly with the husky brake line!
    I have also heard that Honda ones fit too.
  6. duggoey Husqvarna
    NSW, Australia
    2010 TE 310
    KTM 690, Yamaha WR200, FGS650(800cc)
    Very nice. Pre 2009-2010 forks are 50mm Zokes rather than 48mm KYB, will those fit the 50mm units? Also do you have to drop the fork to fit the wrap around ones?
  7. PowerKord Husqvarna
    Notheast Ohio
    2008 WR 250 Sold
    2014 Sherco SE-R 250
    My 2008 has 45mm Zokes, they have a different mounting pattern than those guards in the pics.
  8. dan s Husqvarna
    united states N.J
    2013 wr 250 A-Class
    A friend of mine sent me the picture so I don't know the details. I assume they fit on the kyb forks.
  9. Enduro450 Husqvarna
    New Zealand
    Yep, fit on my 13 txc with the kyb's and my 08 txc with the 50mm zokes.
    You do have to drop the forks if you get the genuine KTM ones, the Gasgas/polisport ones unclip at the back so they just slip on and clip up.
    duggoey likes this.
