250-500cc KYB Oil Height
Discussion in '2 Stroke' started by woodzi, Mar 14, 2013.
  1. woodzi Husqvarna
    Waterloo, ON
    Just about ready to finish up a fork service, but I can't find the oil height anywhere. My service manual has the info for the Marzocci forks only :(.
    Does anyone know what the recommended height is for the open chamber KYB's?
  2. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    You can call Ziptyracing 760-244-7028
    pvduke likes this.
  3. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
    You can run anywhere from about 150mm to 80mm in the OC KYB. I normally set them about 125mm, but some faster guys like 100mm.
  4. pvduke Husqvarna
    ... on the gas...
    tripple-hondo hoosk...
    i run about 110mm for light springs up to .46 then 115-120 for heavier than that based on feedback.
    but- if you know your set-up and have a lot of info on where you ride the most by all mean CALL Zipty for some good dope!
  5. woodzi Husqvarna
    Waterloo, ON
    Thanks. I set them at 95mm and installed .44 springs. I think the springs might still be a bit light, but the extra oil might help stop some of the bottoming. We will see if the snow ever melts.
    These forks are very easy to work on, so easy to go back in if I need to.
