Lambda Connector Source
Discussion in 'EFI/carb' started by Nesbocaj, May 29, 2009.
  1. Nesbocaj Husqvarna
    Exact fit!
    From Eastern Beaver http://tinyurl.com/ksj2lq
    PART# 4P090WP-MT
    Crazy thing is that I looked everywhere for these, then found them here, a place I frequently shop, DOH!
    Jim, the owner is a good dude, and a rider. He is located in Japan and I receive
    almost everything I order from him, in about 5 days, amazing!
    Bob
  2. PALMER84ONE Husqvarna
    Silverado, CA.
    08 TE450 THE ROCKET
    12 RS520, CRF150F/230F, YZ250
    Good to know. How much $$ are we talking?
  3. palmczak Husqvarna
    Granby, CO
    Nice find! I just ordered them. Once they show up I will have a reason to pull the tank and make a permanent switchable setup.
  4. Nesbocaj Husqvarna
    $5.95 each set (both sides, plugs, ends) IIRC $6 shipping Japan to NY.
  5. Nesbocaj Husqvarna
    If I understand your relay set-up; it removes the signal and ground from the circuit and powers the heater wires to the lambda.
    I tried this today, and a few other variations, and could not get the second map loaded. I test rode between tries and am certain, by how it runs, which map is which.
    The only way that worked for me was to install the resistor and as I did not want to leave the sensor unheated for any length of time, I have removed the sensor, and put a bung in its place.
    Have you ridden the bike with the resistor and let me know, it you would, if I understand your circuit?
    Thanks!
    Bob
  6. seymore Husqvarna
    Boise, ID
    Here is a few things to consider...
    My tests have shown the ECU only checks for the PU resistor at power up or maybe engine start.
    If you switch the O2 sensor heater from the ECU, applying 12V continuously maybe to much heat. I my testing I have seen that the ECU modulates the heater voltage to likely control the sensor element temperature. You may need to install a current limiting resistor inline on the switched circuit to keep from over heating the sensor.
