Late 70's cases?.
Discussion in 'Vintage/Left Kickers' started by Bigbill, Oct 2, 2016.
  1. Bigbill Husqvarna
    '83 250wr
    0 right now
    Ok I need a refresh. Assembling the late 70' cases we need to time the tranny in the correct gear for assembly. I think it's two teeth on the shifter gear in third gear on the drum.?
    I'm working on the piston and cylinder for now. Time to build engines.
  2. Crashaholic Husqvarna
    Antelope Valley, CA.
    73 450WR 6spd motor in a 75 MK frame
    You're right about the 2 teeth of the step feeder being visible at the top of the shifter drum and one at the bottom but when setting up a late 70's six speed the trans must be in fourth gear. You must have been thinking of the early to mid 70's five speed because it uses the third gear setting.
    oldbikedude likes this.
  3. Bigbill Husqvarna
    '83 250wr
    0 right now
    Fourth gear with two teeth showing on the feeder. That's it thanks. People make a note of this timing when assembling the older mid 70's to 80's cases.
