Lectron 250/300 metering rod testing results.
Discussion in 'Motosportz' started by Motosportz, Apr 28, 2014.
  1. Motosportz CH Sponsor
    I did a bunch of testing this weekend on the 250/300 rods. Went through a bunch of them. My bike was running very good (much better than stock) with the 3-1 we ship with but felt for my riding style (lugging a lot on technical trails) and temps (mild) the 3-1 rod might be slightly lean. Like I said my bike ran great but seemed like it should have more pull and felt semi lean. I tried a bunch of different rods and settled on the 3-2. This adds more bottom and mid fuel and ends up the same on top. This for me and my bike added a good bit of torque / pulling power. I still need to adjust it as I am slightly rich now but I am nit picking. It for sure has more bottom end power, nice mid and same top. Feels like I put a high comp piston or went from a 250 to a 300 type thing. Just more meaty pull.
    For guys in hotter temps or wanting better MPG the 3-1 is probably the right rod. For trail luggers in milder temps you might want to give the 3-2 rod a try. These are readily available from Lectron or if there is a lot of interest I'll stock them and sell them at my cost to get them to my customers. I feel this is a noticeable improvement on an already good running setup. If you feel your bike does not pull as hard as it should or feels slightly lean it might be worth a go. I really liked the added pull down low and into the mid and felt it pulled a good bit better up big hills and coming out of corners a gear high. Kinda gives the sensation of more cc's.
    Thanks
    Kelly
    Mz
  2. dukepilot Viva l'Husqvarna d'Italia!
    Morgan Hill, CA
    450 SMR, TE250, CR125, SM610
    Duc, Buell, Honda
    Appreciate the work you put into these carbs and your info sharing!
    Motosportz likes this.
