Lectron float bowl leak
Discussion in 'EFI/carb' started by venturini, Feb 15, 2014.
  1. venturini Husqvarna
    USA
    '15 TC 250 '13 CR 150 '11 TE 310
    '12 KTM 250 XC
    Who else has had an issue with the clear float bowl of the Lectron leaking? I recall a thread a while back but could not find it with a search. Is there a new design for the gasket? I got the carb last summer through Motosportz.
  2. Motosportz CH Sponsor
    Yes there is a Viton gasket. Call Lectron and they will set you up. I'm having all my carbs built from here on out with them pre-installed.
  3. venturini Husqvarna
    USA
    '12 KTM 250 XC
    Sounds good---thanks
  4. Eaglefreek Husqvarna
    Fayetteville,TN
    11 WR300
    I also have a little leakage and called Lectron to order one and they said it's not for the bowl that has an oring. :confused:
  5. venturini Husqvarna
    USA
    '12 KTM 250 XC
    Interesting.....according to their site they state that the "old" style gasket can be used "in addition" to the o-ring for extra sealing.
  6. Motosportz CH Sponsor
    Huh? who did you talk to? Is for the the bowl with the o-ring. Call them again and ask for Kevin.
  7. Eaglefreek Husqvarna
    Fayetteville,TN
    11 WR300
    I don't want to throw anyone under the bus, it wasn't Kevin. I'll just call again and order it. Thanks
    Motosportz likes this.
