Lectron install 13 wr 250
Discussion in 'EFI/carb' started by Johnny105, Jan 31, 2014.
  1. Johnny105 Husqvarna
    Clovis, New Mexico
    13 WR250 (Sold), 14 WR300
    12 KTM 50sx (daughters), 14 RMZ450
    Installed it right out of the box. Bike is rich so i took 1/2 counter clockwise turn out of the metering rod. wouldnt idle to run unless i have the choke on. put it back to stock same problem. What did i do wrong? i installeda fresh plug also.
  2. Motosportz CH Sponsor
    These two things contradict each other. If you have to have the choke on it is lean. You did reindex the rod so the flat side faces the motor right? 99% of the time these run very good right out of the box with a little teaking done to them if needed. PJ should be set to about one turn out. Pretty stock bike or mods?
  3. Johnny105 Husqvarna
    Clovis, New Mexico
    So frustrated I put the stocker back on.
  4. 454x Husqvarna
    Dunnigan,Ca.
    2012 CR165 w/36mm lectron.
    Don't give up so easily. Its a really simple carb to set up.
  5. Long_Stroke Husqvarna
    Logan, Utah
    2011 WR300, 2013 WR144, 2020 FE501s
    1996 DR350, 2002 Aprilia Caponord
    I had to turn down the power jet to zero to get mine fine tuned at idle and mid-RPM, then dial up the power jet to run good at full throttle. My power jet is only turned out 1/2 turn or so. I need to cut down the power jet tube, apparently. I think the 36mm carb with the 300 creates a pretty strong effect on the pickup tube for the power jet.
    I left my muffler plug in when installing mine and it wouldn't start for hours until I noticed that!
  6. Motosportz CH Sponsor
    WTF a bunch of my posts from yesterday disappeared. I looked through my records, don't think you got it from me. Need more info on your carb and your setup. Should be EZ to get to work well. PM me your phone number and a good time to call you.
  7. Motosportz CH Sponsor
    :) I have done this and also left a plastic bag over my air filter after washing the airbox. Started fine but would not rev very well. :eek:
  8. johnnyboy Husqvarna
    UK
    WR 125
    TM 250f
    Make sure the flat side of the metering rod if facing the reed side, They run with the symtoms you discribe with the rod 180 out.
    jmetteer and Motosportz like this.
  9. Motosportz CH Sponsor
    Yes, read the instructions well and understand the carb. It is simple once understood.
